Старый 18.07.2019, 10:13   #1
alirazazaidi: Error CREATE UNIQUE INDEX ON DBO.PROJHIERARCHYSORTING Dynamics 365 for finance and Operations
Источник: https://www.tech.alirazazaidi.com/er...nd-operations/
I faced this problem while restoring staging database from 8.0 to latest version.
Microsoft did not provide any solution to extended index. You can add new indexes on table extension, but did remove or modified on existing indexes.
Severity    Code    Description    Project    File    Line    Suppression State
Error        CREATE UNIQUE INDEX I_17901NODEREFERENCE ON DBO.PROJHIERARCHYSORTING(PARTITION,DATAAREAID,TYPE,REFID,REFNODEID); —> System.Data.SqlClient.SqlException: The CREATE UNIQUE INDEX statement terminated because a duplicate key was found for the object name ‘dbo.PROJHIERARCHYSORTING’ and the index name ‘I_17901NODEREFERENCE’. The duplicate key value is (5637144576, atd, 0, , 0).            0
One solution I found that DBO.PROJHIERARCHYSORTING is have some kind of sorting data, And When we open Work Break down structure
this table is auto populate some kind of internal usage for sorting.
So I truncate the DBO.PROJHIERARCHYSORTING table and as result Database Synchronization successfully completed.
And opening WBS of existing table, I found data at SQL server level.
Happy DAXING.
There is no solution to extend table index on table.  So only solution to truncate the table.
alirazazaidi: List of best blog post and article for Customization with extensions. Dynamics 365 for finance and operations Blog bot DAX Blogs 0 05.01.2019 12:19
powerobjects: How to Integrate Power BI with Dynamics 365 for Finance and Operations Blog bot Dynamics CRM: Blogs 0 26.06.2018 01:23
survivingcrm: What’s An “App” in Dynamics 365 Anyway? Blog bot Dynamics CRM: Blogs 0 06.01.2018 22:14
Часовой пояс GMT +3, время: 16:46.
