Старый 02.04.2019, 15:11   #1
crmtipoftheday: Tip #1246: Use “Get Record” to get all the fields in Flow
Источник: https://crmtipoftheday.com/1246/use-...ields-in-flow/
You create a Flow that runs when a record is updated. Occasionally the Flow fails on one or more step with a template error that reads something like the following:
Unable to process template language expressions for action ‘Check_if_Last_Name_contains_data’ at line ‘1’ and column ‘1823’: ‘The template language expression ‘triggerBody()[‘lastname’]’ cannot be evaluated because property ‘lastname’ doesn’t exist.
You think: of course the lastname property exists–it’s one of the standard fields and it is available to be selected from the field list.
Not so fast–take a look at your failed flow and expand out the when a record is updated. You will notice that none of the fields that do not contain data (nulls) is included in the list.
If you will be referencing fields from the updated record, insert a get record step after the when a record is updated step–then when you reference a field from the record that equals null, the Flow will succeed.
crmtipoftheday: Tip #1205: Local time in Flow using Common Data Service Blog bot Dynamics CRM: Blogs 0 06.12.2018 18:11
crmtipoftheday: Tip #1124: Flow Approvals May Be Exactly What You Need Blog bot Dynamics CRM: Blogs 0 25.06.2018 12:11
crmtipoftheday: Tip #1094: It is Time to Go with the Flow Blog bot Dynamics CRM: Blogs 0 27.03.2018 09:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
Часовой пояс GMT +3, время: 23:35.
