Старый 14.02.2019, 19:06   #1
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Post D365FO Platform Update 21 (7.0.5073) KB 4477851 bug fixes
Надеюсь, не раскрою большого секрета, если опубликую список исправлений для Platform Update 21
  • KB 4469076 Client
    URL EDT link is frequently opening blank pages in IE
  • KB 4469077 Client
    Asterisk does not display for some required fields
  • KB 4469078 Client
    Real value lookup does not work for languages where decimal separator is a comma instead of a dot, like in German “de”
  • KB 4469079 Data Management
    Attachment entities not working when imported using DMF API
  • KB 4469081 Data Management
    Data Management: XML transformation temporary files are not deleted and will eventually result in error “System.Exception: The file exists”
  • KB 4469087 Extensibility
    Cannot expose a custom field from VendTable on any entity
  • KB 4469088 Extensibility
    Control name overrides the declared variable name during CoC implemtation in form extension class
  • KB 4469074 Office Integration
    Paperclip icon does not show the correct count of the files attached
  • KB 4469082 Performance
    Error message recommends specifying a Maximum buffer size value of 194 Kbytes or higher on the Database Tuning tab page in the Microsoft Dynamics 365 for Finance and Operations Server Configuration Utility
  • KB 4469084 Performance
    Audit Trail: Incorrect syntax error while creating a new alert rule
  • KB 4469086 Performance
    NestedLoop does not work on some form datasources as expected
  • KB 4469089 Programming Model
    Incorrect compare in the “Import project” dialog if the project contains more than 1 element.
  • KB 4469090 Programming Model
    “Find tag references” doesn't work for object type Class
  • KB 4469091 Runtime
    Incomplete Transaction Metadata
  • KB 4469075 Task Recorder
    Unable to edit a recording after marking a column in the task list
  • KB 4469067 Translation
    Mass search and replace of word “state” results in incorrect messages in Retil module for en-ca, en-ie, and en-sg
  • KB 4469071 Translation
    [Apply button on grid filtering] Translations issues for all FR languages
За это сообщение автора поблагодарили: Logger (5).
d365 for operations, d365fo
D365FO - Platform update против Platform and application binary package - Что? Где? Когда? MarinaAX DAX: Администрирование 1 06.02.2019 03:19
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
dynamicsaxse: December Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 04.01.2018 03:46
stoneridgesoftware: Microsoft has Released the 4th Platform Update for Dynamics 365 for Operations Blog bot DAX Blogs 0 12.04.2017 02:30
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 23:16.
