Старый 03.12.2018, 18:11   #1
crmtipoftheday: Tip #1202: Editable grid control not working in subgrids
Источник: https://crmtipoftheday.com/1202/edit...g-in-subgrids/
I enabled the editable grid control on a subgrid, but after publishing, I still see the read-only grid in the subgrid in classic UI. The grid is editable in unified interface. What’s up?
Gridless reader
Chances are you have legacy form rendering enabled in your environment system settings. Disable legacy form rendering and your subgrid will be editable.
(Cover photo by Ricardo Gomez Angel on Unsplash)
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
crmtipoftheday: Tip #1183: Templates are not working after upgrade Blog bot Dynamics CRM: Blogs 0 31.10.2018 14:11
crmtipoftheday: Tip #1181: Filtered lookups on editable grids Blog bot Dynamics CRM: Blogs 0 22.10.2018 15:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 18:21.
