#1 |
yetanotherdynamicsaxblog: Upgrade from 7.x to 8.+ series | Post 5 | Upgrade Sandbox and finally Production
Источник: http://yetanotherdynamicsaxblog.blog...es-post-5.html
============== Introduction In these series of posts. I will try to run you through the process of how you can complete the upgrade from 7.x to 8.+ of Dynamics 365 for Finance and Operations. Quick navigation: Upgrade from 7.x to 8.+ series | Post 1 | Start in LCS Upgrade from 7.x to 8.+ series | Post 2 | Deploy Dev and Grab source DB Upgrade from 7.x to 8.+ series | Post 3 | Validate Code and Data in Dev Upgrade from 7.x to 8.+ series | Post 4 | Setup a new Build Upgrade from 7.x to 8.+ series | Post 4 | Upgrade Sandbox and finally Production (you are here) Prepare a sandbox upgrade for validation Before you can go ahead and request an upgrade of Production, you will want to do a pre-production validation in the sandbox environment. You may read the details here: https://docs.microsoft.com/en-us/dyn...ox-environment The actual steps are well documented here: https://docs.microsoft.com/en-us/dyn...ox-environment Before you start this process, you will want to make sure you have the following uploaded to LCS Asset Library:
The next steps are simply:
Finally Production When you are ready to do the actual upgrade of Production, the flow is a lot simpler, and very well outlined on the official documentation. So I will simple refer to docs here. Good luck! Источник: http://yetanotherdynamicsaxblog.blog...es-post-5.html
