Старый 04.09.2018, 22:15   #1
dynamicsnavax: Print a Sales Invoice via X++ in #MSDyn365FO
Источник: http://dynamicsnavax.blogspot.com/20...sdyn365fo.html
Often you want to print a report via X++. One of the more common reports is the sales invoice.
Below is some code you could use to download a pdf copy. I am just picking the first invoice and printing to pdf.
Next few posts will be dependent on this. I will try to build up the scenario.
public static void printSalesInvoice()
CustInvoiceJour custInvoiceJour;
select firstonly custInvoiceJour
where custInvoiceJour.SalesId != '';
if (custInvoiceJour)
str ext = SRSPrintDestinationSettings::findFileNameType(SRSReportFileFormat::PDF, SRSImageFileFormat::BMP);
PrintMgmtReportFormatName printMgmtReportFormatName = PrintMgmtDocType::construct(PrintMgmtDocumentType::SalesOrderInvoice).getDefaultReportFormat();
SalesInvoiceContract salesInvoiceContract = new SalesInvoiceContract();
salesInvoiceContract.parmRecordId(custInvoiceJour.RecId);
SrsReportRunController srsReportRunController = new SrsReportRunController();
srsReportRunController.parmReportName(printMgmtReportFormatName);
srsReportRunController.parmExecutionMode(SysOperationExecutionMode::Synchronous);
srsReportRunController.parmShowDialog(false);
srsReportRunController.parmReportContract().parmRdpContract(salesInvoiceContract);
SRSPrintDestinationSettings printerSettings = srsReportRunController.parmReportContract().parmPrintSettings();
printerSettings.printMediumType(SRSPrintMediumType::File);
printerSettings.fileFormat(SRSReportFileFormat::PDF);
printerSettings.parmFileName(custInvoiceJour.InvoiceId + ext);
printerSettings.overwriteFile(true);
srsReportRunController.startOperation();
dynamicsaxse: November 2017 Release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 08.12.2017 10:51
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
Dynamics AX Sustained Engineering: Sale Order Batch Invoicing reprints invoices from prior runs, when “Print” is set to ‘After’ on AR >> Periodic >> Sales Update >> Invoice form Blog bot DAX Blogs 0 24.03.2010 02:06
C# and AX Development: How to print a different Sales Invoice per company in AX Blog bot DAX Blogs 0 26.08.2008 23:05
Часовой пояс GMT +3, время: 13:36.
