Старый 06.06.2018, 21:11   #1
How to add a new report for a business document in D365
Источник: http://alexvoy.blogspot.com/2018/06/...-business.html
My colleague Rod showed it to me when I needed to add a new report to Project Invoice Proposal with billing rules to be present in Print management settings.
/// Subscribes to print mgmt report format publisher to populate custom reports
[SubscribesTo(classstr(PrintMgmtReportFormatPublisher), delegatestr(PrintMgmtReportFormatPublisher, notifyPopulate))]
public static void notifyPopulate()
#PrintMgmtSetup
void addFormat(PrintMgmtDocumentType _type, PrintMgmtReportFormatName _name, PrintMgmtReportFormatCountryRegionId _countryRegionId = #NoCountryRegionId)
avrPrintMgtDocType_ProjInvReport_Handler::addPrintMgmtReportFormat(_type, _name, _name, _countryRegionId);
addFormat(PrintMgmtDocumentType::SIProjInvoiceWithBR, ssrsReportStr(avrPSAContractLineInvoice, Report));
/// Adds a report format to the printMgtReportFormat table
/// PrintMgmtDocumentType value
/// Name of the report (ie. reportname.Report)
/// Description of the report (ie. reportname.Report)
/// Country or default (#NoCountryRegionId)
/// True if this is a system report
/// SSRS report or another type
private static void addPrintMgmtReportFormat(
PrintMgmtReportFormatDescription _description,
PrintMgmtReportFormatCountryRegionId _countryRegionId,
PrintMgmtReportFormatSystem _system = false,
PrintMgmtSSRS _ssrs = PrintMgmtSSRS::SSRS)
PrintMgmtReportFormat printMgmtReportFormat;
select firstonly printMgmtReportFormat
where printMgmtReportFormat.DocumentType == _type
&& printMgmtReportFormat.Description == _description
&& printMgmtReportFormat.CountryRegionId == _countryRegionId;
if (!printMgmtReportFormat)
// Add the new format
printMgmtReportFormat.clear();
printMgmtReportFormat.DocumentType = _type;
printMgmtReportFormat.Name = _name;
printMgmtReportFormat.Description = _description;
printMgmtReportFormat.CountryRegionId = _countryRegionId;
printMgmtReportFormat.System = _system;
printMgmtReportFormat.ssrs = _ssrs;
printMgmtReportFormat.insert();
Then I can pick it up in Print management settings in Project module.
It may be a good idea to delete records from PrintMgmtReportFormat table; all its records will be recreated the next time you open Print management form.
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Часовой пояс GMT +3, время: 18:02.
