Старый 18.11.2017, 03:51   #1
ievgensaxblog: D365FOE. Get list of installed metadata hotfixes using Metadata API.
Источник: https://ievgensaxblog.wordpress.com/...-metadata-api/
We can retrieve  information about metadata hotfixes installed directly from Visual Studio using “Apply Hotfix” addin ( Dynamics 365 -> Addins -> Apply Hotfix).
But who wants to click that button if we can write X++ job ?   All information could be retrieved using powerful  Metadata API.
public static class ShowAllInstalledHotfixes
    public static void main(Args _args)
        var environment = Microsoft.Dynamics.ApplicationPlatform.Environment.EnvironmentFactory::GetApplicationEnvironment();
        Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvider metadataProvider = ShowAllInstalledHotfixes::getDiskMetadataProvider(environment);
        // or runtime
        // Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvider metadataProvider = ShowAllInstalledHotfixes::getRuntimeMetadataProvider(environment);
        Microsoft.Dynamics.AX.Metadata.Providers.IMetaUpdateProvider updateProvider = metadataProvider.get_Updates();
        var moduleInfoList = metadataProvider.ModelManifest.ListModules();
        var i = moduleInfoList.GetEnumerator();
        setPrefix('KBs Installed');
        while (i.MoveNext())
            Microsoft.Dynamics.AX.Metadata.MetaModel.IModuleInfo moduleInfo = i.get_Current();
            System.String moduleName = moduleInfo.get_Name();
            setPrefix(moduleName);
            var updatesEnumerator = updateProvider.ListObjects(moduleName).GetEnumerator();;
            while (updatesEnumerator.moveNext())
                System.String axUpdateName = updatesEnumerator.get_Current();
                Microsoft.Dynamics.AX.Metadata.MetaModel.AxUpdate axUpdateObject = updateProvider.Read(axUpdateName);
                utcdatetime appliedDateTime = axUpdateObject.get_AppliedDateTime();
                setPrefix(strFmt('Name %1, Applied %2', axUpdateObject.get_Name(), appliedDateTime));
                var n = axUpdateObject.get_KBNumbers().GetEnumerator();
                while (n.MoveNext())
                    info(n.get_Current());
    public static Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvider getDiskMetadataProvider(Microsoft.Dynamics.ApplicationPlatform.Environment.IApplicationEnvironment _environment)
        Microsoft.Dynamics.AX.Metadata.Storage.DiskProvider.DiskProviderConfiguration diskProviderConfiguration = new Microsoft.Dynamics.AX.Metadata.Storage.DiskProvider.DiskProviderConfiguration();
        diskProviderConfiguration.AddMetadataPath(_environment.get_Aos().get_PackageDirectory());
        Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactory metadataProvicerFactory = new Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactory();
        return metadataProvicerFactory.CreateDiskProvider(diskProviderConfiguration);
    public static Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvider getRunTimeMetadataProvider(Microsoft.Dynamics.ApplicationPlatform.Environment.IApplicationEnvironment _environment)
        Microsoft.Dynamics.AX.Metadata.Storage.Runtime.RuntimeProviderConfiguration runtimeProviderConfiguration = new Microsoft.Dynamics.AX.Metadata.Storage.Runtime.RuntimeProviderConfiguration(_environment.get_Aos().get_PackageDirectory());
        return metadataProvicerFactory.CreateRuntimeProvider(runtimeProviderConfiguration);
Result
As you can see, there are two methods to create Metadata provider: one for disk and another one for runtime. Runtime provider does not return AppliedDateTime or Name, so I assume that they do not exist at runtime. Disk provider has this information but, as you know, we have source code only in dev environments.
Source code on GitHub.
Последний раз редактировалось mazzy; 18.11.2017 в 08:29.
ievgensaxblog: D365FOE. Issue with enums that have “Use Enum Value” property set to “No”. Blog bot DAX Blogs 0 15.10.2017 11:12
goshoom: New metadata API Blog bot DAX Blogs 0 04.11.2016 00:11
emeadaxsupport: How to get the Production Picking list to Use the delivery note layout Blog bot DAX Blogs 0 13.03.2015 22:13
Microsoft Dynamics CRM Team Blog: Marketing with Dynamic List Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Часовой пояс GMT +3, время: 03:12.
