Старый 23.10.2017, 20:13   #1
25,644 / 848 (80) +++++++
axtoday: Testing Dynamics 365 for Operation Recurring Integrations with Postman
Источник: http://axtoday.blogspot.com/2017/08/...operation.html
Continuing on the last post, let's do some tests on the D365O recurring integrations with Postman.
Initial setup
We still need the "GetToken" call as before. Please check on the previous post for information on how to set this up.
Next on the D365O data management workspace, we need to create an import and an export projects. To make it simple, let's use the "Customer groups" entity.
Create an import project as usual, and you need to create a sample of import file. Once you click the "Upload" button, then click the "Create recurring data job" button at the top. You will then need to:
  • Specify a name
  • Specify the application ID, and tick the checkbox beside it
    (This is the client ID that we use in the GetToken call)
  • Click the "Set processing recurrence" and set the job recurrence
  • Click the "Set monitoring recurrence" and set the monitoring recurrence
  • Keep note of the job ID
  • Click OK
Next, create an export project as usual. After you click the "Add entity" button, then click the "Create recurring data job" button at the top. You will then to do the same as above.
Send a file to the recurring import job
Open Postman, and execute the "GetToken" call to get the access token. Then create a new POST call with this url https:///api/connector/enqueue/?entity=
Activity ID is the job ID that was displayed when you created the recurring jobs.
Then click on the Body tab, choose Binary, and click the "Choose Files" button to choose the import file. After that just click the "Send" button.
If it's successful, it will return with a job ID and HTTP 200.
You then can inquire the status of the job by doing a GET call to this url: https:///api/connector/jobstatus/?jobId=
The result will then show you the job status, including the job started/completed date time and execution logs
Please note that you always need to add the authorisation and the access token in the message header with every call.
Receive a file from the recurring export job
Open Postman, and execute the "GetToken" call to get the access token. Then create a new GET call with this url https:///api/connector/dequeue/
If it's successful, it will return with a download location and HTTP 200.
Then you'll need to create a new GET call and use the download location as the URL, and then instead of clicking the "Send" button, you'll need to click the "Send and Download" button. Postman will then display a dialog where you can use to select the location where you want the file to be saved.
After downloading the file, you should send an acknowledgement:
https:///api/connector/ack/
"CorrelationId": "",
"PopReceipt": "",
"DownloadLocation": ""
The body (correlationId, popReceipt, downloadLocation) should be the same as the body from the original dequeue request.
dyn365finsupport: Dynamics 365 for Sales (CRM) Initial Setup and Synchronization with Dynamics 365 for Financials Blog bot NAV: Blogs 0 05.04.2017 04:33
jaestevan: Dynamics 365, AppSource, PowerApps y compañía… ¿Qué esperar del futuro de los ERP en Microsoft? Blog bot DAX Blogs 0 26.07.2016 22:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 8 Blog bot Dynamics CRM: Blogs 1 30.04.2016 10:26
Часовой пояс GMT +3, время: 09:48.
