Старый 14.09.2017, 13:11   #1
25,644 / 848 (80) +++++++
dynamicsaxinsight: AX7/D365/Operations: Data import using data entities
Источник: https://dynamicsaxinsight.wordpress....data-entities/
Purpose:
The purpose of this document is to demonstrate how we can import data using data entities in Dynamics 365 for Operations.
Prerequisites:
  • Access to Dynamics 365 for Operations instance via remote desktop.
  • To be provisioned as an administrator for the instance.
Business requirement:
Ability to import/migrate legacy business data to Dynamics 365 for Operations.
Process:
1. Navigate to Workspaces > Data management > Import.
2. Enter job details as shown below. We have selected a custom data entity Raw material in this scenario. You can safely use any standard data entity instead.
3. Click Upload to select and upload the source data file.
4. Click View map to generate field mappings.
5. On Map source to staging screen, click Mapping visualization.
6. Define the mapping. Click Save.
7. Now go back to the job screen and click Import.
8. At the end of the execution, you should see the Execution summary.
9. You can verify the data loaded by navigating to the relevant form. In this case Raw Materials details master form.
dynamicsaxinsight: AX7/D365/Operations: Create Details Master pattern form Blog bot DAX Blogs 0 14.09.2017 13:11
dynamicsaxinsight: AX7/D365/Operations: Create custom data entity Blog bot DAX Blogs 0 14.09.2017 13:11
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 14:22.
