Старый 10.08.2017, 07:12   #1
organicax: Building a measure to publish to the entity store – Part 5
Источник: https://organicax.com/2017/08/09/bui...-store-part-5/
In the previous post we created new data entities and import our sample data. In this post we’ll create a query and a view. The Aggregate measure will use the view as it’s data source. In this example as we created new tables we created all the objects but if you are using existing tables then this is where you would likely start to create your own query and views to pull together the data you want to include in the aggregate measurement.
Here is a quick overview.
D365 July 2017 Update 8 (7.0.4565.16211)
In the next post we’ll actually create the aggregate measurement.
Cheers
Lachlan
Filed under: Business intelligence
organicax: Building a measure to publish to the entity store – Part 6 Blog bot DAX Blogs 0 10.08.2017 07:12
organicax: Building a measure to publish to the entity store – Part 1 Blog bot DAX Blogs 0 10.08.2017 00:17
stoneridgesoftware: Part I: Configuring the Dynamics AX 2012 R3 Entity Store Blog bot DAX Blogs 0 27.04.2017 12:11
organicax: Setting up an entity store in AX2012 R3 CU11 Blog bot DAX Blogs 0 21.02.2017 09:11
dynamics-coe: Microsoft Dynamics AX 2012 Reporting Services - Issue deploying OLAP SSRS reports on SharePoint 2013 Blog bot DAX Blogs 0 25.01.2015 12:17
Часовой пояс GMT +3, время: 23:52.
