Старый 20.02.2017, 04:11   #1
waldo: Make the New Developer Tools available on a local machine
Источник: https://dynamicsuser.net/nav/b/waldo...-local-machine
On Titter, Mark Brummel was wondering on how we would be able to get this wonderful new DEV environment locally, to be able to play with whenever we don’t have an Internet Connection. Well .. by coincidence, I had been trying to wrap my head around that a few weeks ago .. but never wrote up a procedure to do that. Well .. to help an old friend .. let’s do just that ;-).
Step 1: Install a new cloud-version of the DEV Tools.
You probably did this already. Just go to http://aka.ms/navdeveloperpreview and create yourself a VM.
Step 2: Create iso and zip of the needed resources
The resources that we need, is the DVD, the VSCode extension and sample code. I will make it easy on you. Just execute this script, and you’re good to go:
https://github.com/waldo1001/Cloud.R...AzureImage.ps1
You see it will find, install and use my PowerShell modules because it needs it to create the ISO and Zip files. When the script is executed, you’ll end up with two files which you need to copy to your local environment.
This can obviously take a while .. .What I did, I copied them on the local “C:\_Installs” folder on my local VM where I wanted to make these new Developer Tools available:
Step 3: Install NAV from the downloaded DVD to your local environment
I am all into local VMs. I never install NAV on my local host, my laptop. I always have an empty VM snapshot with Win2016 ready to install anything on it. So that’s what I have used to do so here as well. If you do it different, then the next steps might be different for you.. .
Again, I want to make it easy for you, and I have foreseen this script for you:
https://github.com/waldo1001/Cloud.R...nvironment.ps1
If you do it exactly as I did (Win2016, copied to C:\_Installs, …), then you should be good to go with this script. Else, you can just try to either change the parameters at the beginning of the script, or read the script and figure out these steps yourself, and do it manually (or step-by-step in PowerShell):
  • Install NAV from the ISO file. The config I use is simply a full install of NAV
  • Unzip the NewDEVTools.zip to the folder “C:\DEMO\New Developer Experience”
  • Install VSCode
  • Install the provided al-extension in VSCode (can be found in the folder “C:\DEMO\New Developer Experience”)
  • Create a Navision_main instance (not really necessary, but it just mimics the AzureVM environment
  • Create a WebServerInstance on Navision_main as well
As said, all these steps are done by the script as well – so if you’re lucky (I always seem to be ;-)), you just need to execute the script, and you should be good to go ;-).
Enjoy!
waldo: Microsoft Dynamics NAV 2017 – what’s really new? Blog bot NAV: Blogs 0 13.10.2016 05:22
Microsoft Dynamics CRM Team Blog: Debugging custom JavaScript code in CRM using browser developer tools Blog bot Dynamics CRM: Blogs 0 29.11.2015 23:11
crminthefield: Microsoft Dynamics CRM 2013 CSS Style Reference using Browser Developer Tools Blog bot Dynamics CRM: Blogs 0 08.07.2014 01:12
Microsoft Dynamics CRM Team Blog: Part 2: IE 8 Developer Tools and CRM 4 – Client Side Debugging Blog bot Dynamics CRM: Blogs 0 07.04.2009 08:05
Nav developer: Overview of NAV blogs in 2008 Blog bot Dynamics CRM: Blogs 0 07.12.2008 02:18
Часовой пояс GMT +3, время: 03:47.
