Старый 17.10.2016, 23:11   #1
25,644 / 848 (80) +++++++
organicax: Operation relations and the production order route
Источник: https://organicax.com/2016/10/17/ope...n-order-route/
When you are doing route maintenance you need to consider the existing production orders in the system and the effect of the route change. When you create a production order the current active route is copied over to a production route. This is a handy concept because it means you can change routes and it won’t affect the existing created production orders. But if you plan production and have firmed production order sitting in the system for, lets say, the next month then you might need to consider if you have to go an change those.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
Часовой пояс GMT +3, время: 07:55.
