Старый 19.09.2016, 14:11   #1
organicax: Counting Group – Counting Code – Manual
Источник: https://organicax.com/2016/09/18/cou...g-code-manual/
When setting up counting groups you can specify a counting code of manual. This might be helpful for items that you want to control and count when you feel appropriate. These could be small invaluable items like nuts and bots that you will count at some point in the accounting cycle. You can set the counting code to manual in the group to allow you to find these items.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Supply chain planning, Warehouse management
organicax: Compile of posts on Counting group – Counting codes setup. Blog bot DAX Blogs 0 19.09.2016 14:11
organicax: Counting group – Counting Code – Minimum Blog bot DAX Blogs 0 18.09.2016 04:14
organicax: Counting group – Counting Code – Zero in stock Blog bot DAX Blogs 0 17.09.2016 21:14
Поставщик Учетная Группа anatol33 NAV: Программирование 9 25.05.2009 22:17
Часовой пояс GMT +3, время: 22:42.
