Старый 03.05.2016, 18:12   #1
emeadaxsupport: Using Currency Translation with Management Reporter and AX
Источник: https://blogs.msdn.microsoft.com/axs...porter-and-ax/
To use currency translation in Management Reporter, you must first set up your currencies and rates in AX. The following lists the items that must be set up in AX. Currencies (General Ledger | Setup) – currencies are created Exchange Rate Types (General Ledger | Setup) – exchange rate types are created (aka Exchange Rate... Read more
dynamicscpm: What do I need to configure in Dynamics AX to get the most out of Management Reporter? Blog bot DAX Blogs 0 31.08.2013 01:18
dynamicscpm: Consolidations and Currency Translation in Management Reporter Blog bot DAX Blogs 0 12.12.2012 00:11
dynamicscpm: Management Reporter and Dynamics AX currency translation Blog bot DAX Blogs 0 09.10.2012 23:12
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating with multiple Dynamics AX 2009 instances (AOS) and/or if currency translation and eliminations are required (Part 4 of 7) Blog bot DAX Blogs 0 07.01.2012 03:18
Часовой пояс GMT +3, время: 19:57.
