Старый 11.10.2004, 14:08   #1
Hamster is offline
Hamster
? Как программно создать журнал переноса и разнести?
В BenchMark пример только для польз. интерфейса
Старый 11.10.2004, 14:31   #2
George Nordic is offline
George Nordic
Аватар для George Nordic
4,480 / 1256 (50) ++++++++
Записей в блоге: 9
Что-то типа того:
PHP код:
    SalesLineTransfer_FLX   salesLineTransfer;
InventDim               inventDimTo;
InventJournalName       inventJournalName;
InventJournalTable      inventJournalTable;
InventJournalTrans      inventJournalTrans;
LineNum                 lineNum 0;
JournalTableData        journalTableData;
JournalTransData        journalTransData;
JournalTransMap         journalTrans_last;
select firstfast firstonly inventJournalName
        where inventJournalName
.JournalNameId   == SalesParameters.SalesLineTransferJournalId_FLX
&& inventJournalName.JournalType     == InventJournalType::Transfer;
    if (
inventJournalName.RecId == 0)
        throw
error("?? ????????? ????? ?????????? ?? ?????? ????????!");
ttsbegin;
inventJournalTable.clear();
inventJournalTable.initValue();
inventJournalTable.DeletePostedLines    NoYes::No;
inventJournalTable.Description          inventJournalName.Description;
inventJournalTable.EmplId               EmplTable::userId2EmplId(curuserid());
inventJournalTable.JournalNameId        inventJournalName.JournalNameId;
inventJournalTable.JournalType          InventJournalType::Transfer;
inventJournalTable.VoucherSeqId         inventJournalName.VoucherSeqId;
inventJournalTable.SalesId_FLX          salesTable.SalesId;
inventJournalTable.write();
journalTableData  JournalTableData::newTable(inventJournalTable);
    while
select salesLineTransfer
        where salesLineTransfer
.SalesId     == salesTable.SalesId
&& salesLineTransfer.Marked      == NoYes::Yes
lineNum += 1;
inventDimTo InventDim::findOrCreateInventLocationId(salesLineTransfer.MarkedLocationTo);
inventJournalTrans.clear();
inventJournalTrans.initFromInventJournalTable(inventJournalTable);
journalTransData = new journalTransData(inventJournalTransjournalTableData);
inventJournalTrans.LineNum          lineNum;
inventJournalTrans.TransDate        systemdateget();
inventJournalTrans.ItemId           salesLineTransfer.ItemId;
inventJournalTrans.Qty              = -salesLineTransfer.MarkedQty;
inventJournalTrans.ToInventDimId    inventDimTo.inventDimId;
inventJournalTrans.PriceUnit        1.0;
inventJournalTrans.InventTransId    NumberSeq::newGetNum(InventParameters::numRefInventTransId()).num();
        if (
journalTableData.journalVoucherNum() && journalTableData.journalTable().voucherDraw == JournalVoucherDraw::Entering)
journalTransData.initVoucher(journalTrans_last.voucher,true);
inventJournalTrans.InventDimId      salesLineTransfer.InventDimId;
inventJournalTrans.insert();
        if (
inventJournalTrans.recId)
journalTrans_last inventJournalTrans.data();
inventJournalTable.NumOfLines LineNum;
ttscommit
А как разнести - это уже дело техники (PostJournal)
но я бы это свалил на пользователя... не стал бы автоматом разность.
С Уважением,
Георгий.
За это сообщение автора поблагодарили: Gustav (6).
Старый 11.10.2004, 15:09   #3
Hamster is offline
Hamster
Thanks огромный....
Передача на реализацию... тудыть ее вкачель..
Старый 27.11.2009, 10:38   #4
kornix is offline
kornix
414 / 146 (5) +++++
Я делал через прямую вставку в InventJournalTable и InventJournalTrans.. А поточнее можете сформулировать? Что на входе задачи? :-)
как программно создать документ в DocuView алька DAX: Программирование 5 03.04.2007 18:44
Ссылка на разнесенный журнал переноса kvg6 DAX: Функционал 18 03.04.2007 13:48
Как программно создать платежное поручение? AK9 DAX: Программирование 3 13.09.2006 09:37
Журнал переноса - себестоимость Yprit DAX: Функционал 5 16.09.2004 10:59
программно создать таблицу mne2001 DAX: Программирование 40 13.08.2004 15:46
Часовой пояс GMT +3, время: 03:27.
