Старый 25.04.2016, 21:11   #1
organicax: Purchasing spend analysis reports – data source
Источник: https://organicax.com/2016/04/25/pur...s-data-source/
If you are looking at the supplier spend analysis reports that are listed under procurement and sourcing in AX and you are getting no data that is likely because you don’t have the cubes setup or haven’t processed them to move data into the cubes. There are a few of the reports listed that start with “Spend by” these all run off the cubes. They are handy reports to do some analysis of what you are spending with suppliers. So if you want to run these reports then you will have to setup and process the cubes.
Here is a quick overview
AX2012 R3 CU9
Keep in mind that seeing the data is in the cubes you could also use Excel or some other analysis package to view the data instead of running the SSRS based reports in AX.
Cheers
Lachlan
Filed under: Procurement and sourcing
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
ax-erp: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] Blog bot DAX Blogs 0 18.07.2012 12:11
dax-lessons: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] Blog bot DAX Blogs 0 06.09.2011 00:12
Microsoft Dynamics CRM Team Blog: Use Shared Data Source for custom Microsoft Dynamics CRM reports Blog bot Dynamics CRM: Blogs 0 05.12.2008 00:05
Часовой пояс GMT +3, время: 15:50.
