#1 |
organicax: Setting up the warehouse mobile device portal for a second company
Источник: http://organicax.com/2016/03/08/sett...econd-company/
============== In a previous post we had a look at the install process for creating a new warehouse mobile device portal. If you have multiple companies that you use with advanced warehouse then you will need to install another portal. Here is a quick walkthrough in AX2012 R3 CU9. While I was using CU9 in this example it’s the same for R3 through to CU10. Cheers Lachlan Filed under: Warehouse management Источник: http://organicax.com/2016/03/08/sett...econd-company/
