Старый 02.03.2016, 08:12   #1
axsa: Extensibility in Dynamics AX 2012 R3 CU8 (CRT, RetailServer, MPOS) Part 2 – New data entity
Источник: https://blogs.msdn.microsoft.com/axs...w-data-entity/
Overview This blog is to expand the knowledge you gained in part 1 of the series (http://blogs.msdn.com/b/axsa/archive...os-part-1.aspx). In case you get stuck, I recommended that you make yourself familiar with part 1 first. Some of the information from there is required and assumed. The steps are based on the Dynamics AX 2012 R3 CU8 VM...
emeadaxsupport: Cumulative Update 8 for Microsoft Dynamics AX 2012 R3 now available! Blog bot DAX Blogs 5 24.11.2014 17:06
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using Export To Excel in Dynamics AX to Create Reporting Data Sources Blog bot DAX Blogs 1 12.10.2013 01:13
Часовой пояс GMT +3, время: 05:38.
