Старый 19.05.2015, 18:11   #1
emeadaxsupport: Crash or hang during AX Project or Report Build - Visual Studio 2013 / AX R3 CU8
Источник: http://blogs.msdn.com/b/axsupport/ar...ax-r3-cu8.aspx
Dynamics AX 2012 R3 CU8 now requires Visual Studio 2013. If you're experiencing a crash or hang when attempting to build projects, after installing CU8, please follow the steps outlined below.
1) Open your System Properties. (Right-click start menu, select System, then Advanced System Settings)
2) Click the Advanced tab
3) Click the Environment Variables button
4) Under the System Variables block, add the following value:
a. Variable name = COMPLUS_LoaderOptimization
b. Variable value = 1
5) Once the value has been loaded, restart the AOS service.
6) Close any instances of Visual Studio, re-open and attempt building another AX project or report.
emeadaxsupport: Cumulative Update 8 for Microsoft Dynamics AX 2012 R3 now available! Blog bot DAX Blogs 5 24.11.2014 17:06
bwelcker: Project Adjustment Improvements in AX R3 CU8 Blog bot DAX Blogs 0 16.11.2014 18:17
bwelcker: Straight Line Project Revenue Recognition in AX R3 CU8 Blog bot DAX Blogs 0 16.11.2014 18:17
Dynamics AX Sustained Engineering: Announcing Support for SQL Server, SharePoint, and Office 2013 Service Packs as well as Visual Studio Team Foundation Server and Visual Studio Online Blog bot DAX Blogs 0 09.10.2014 23:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Часовой пояс GMT +3, время: 08:27.
