Старый 20.11.2014, 04:16   #1
DynamicsAxSCM: What’s new in CU8 for WMS and TMS?
Источник: http://blogs.msdn.com/b/dynamicsaxsc...s-and-tms.aspx
The SCM Team are glad to announce the launch of Cumulative Update 8 for Microsoft Dynamics AX 2012 R3. The whole team is thrilled in the interest you have shown for R3 and we are glad to contribute in making Dynamics AX an even better and more versatile solution in the supply chain management areas. This release includes several substantial improvements in warehouse management and transportation management. Microsoft Dynamics AX 2012 R3 CU8 (KB2998197) is available for download using R3 Update Installer on Life Cycle Services. The following information and related articles about what's new in CU8 is available on TechNet.
Within WMS and TMS the following enhancements are made available:
  • Use a load building workbench to automatically build loads based on the templates and strategy that you define.
  • Use cross-docking to move packages of products through a warehouse while using limited or no storage.
  • Set up a company policy for sales order fulfillment and create batch jobs to release sales orders and transfer orders to the warehouse.
  • Allocate batch numbers.
  • Receive items at a different warehouse than expected.
  • Use product variants in warehouse management processes.
The following table shows an excerpt from TechNet on a more detailed list of the enhancements for CU8 in WMS and TMS.
Load building workbench
This load building feature lets you automatically build loads using a load building workbench. You set up filters that define a subset of supply or demand lines, load building templates, and a strategy for load building. At the touch of a button, suggested loads are generated, which can later be turned into actual loads. This feature is designed for extensibility so that advanced load building strategies can easily be plugged in.
For more information, see Automate the process of building loads.
Cross-docking to move packages of products through a warehouse while using limited or no storage
Cross-docking is useful if you purchase products from different vendors, the vendors prepack cartoons that contain a mix of products or product variants, and you want to distribute cartons to one or more retail stores. This feature works with or without the Warehouse management module.
For more information, see Cross docking packages in Warehouse management.
You need to set up a default company policy for sales order fulfillment rates. The policy controls the percentage of the total price or the quantity of an order that must be reserved physical before a sales order can be released to the warehouse. You can also set up a policy for specific customers. Customer-specific policies override the default policy.
For more information, see Sales orders and fulfillment rates in Warehouse management.
Allocate batch numbers in Warehouse management
You can define policies that control when batch numbers are allocated by setting up one or more number groups, and then assigning them to products. It's possible to allocate batch numbers when you perform a physical receipt of a product, or when you create a line that includes a product on a source document, such as a purchase order. You can also manually allocate batch numbers to products.
For more information, see Batch numbers in Warehouse management.
You can set up a mobile device to receive loads or items at a warehouse that differs from the warehouse that was specified on the source document. When you receive the load or item, the load or item is located at the new warehouse and all related work is created for the new warehouse
For more information, see Receive items at a different warehouse than expected.
Product variants are defined by product masters with product dimension variations, for example, a single towel in different sizes and colors. Instead of creating multiple products, you create a single product master and use the various combinations of sizes and colors as different product variants. You can use product variants in the following processes:
• When you define stocking limits.
• When you configure work confirmation and bar code scanning on mobile devices.
• When you create replenishment templates.
• When you set up rules for converting units of measure.
• When you assign fixed warehouse locations.
For more information, see Define pack size categories and location stocking limits, Configure mobile devices for warehouse work, Set up replenishment, Set up a unit sequence group and unit of measure conversions in Warehouse management, and Set up parameters to create a warehouse location.
Use additional production processes in a warehouse
It's now possible to use these additional production processes in a warehouse:
• Direct raw materials to the operation that will consume them on a route.
• Set up a work template to create work to put away finished goods and co-products and by-products from the last operation on a particular production route.
• Direct work to pick up finished goods to the last operation on a production route.
For more information, see Set up production processes in a warehouse.
If you have any question for the SCM team about these new features, don't hesitate to leave a comment below.
DynamicsAxSCM: Third-party Transportation Management (TMS) engines (UPS, FedEx, Progistics, PCMiler) Blog bot DAX Blogs 0 10.10.2014 12:11
DynamicsAxSCM: Transportation management (TMS) mileage engine based on Bing Maps Blog bot DAX Blogs 0 11.07.2014 17:11
Перевод меток в АХ 2012 R3 (WMS & TMS) Atar DAX: Прочие вопросы 8 08.07.2014 17:52
DynamicsAxSCM: Warehouse and Transportation management vs. the “old” Advanced warehouse management Blog bot DAX Blogs 0 27.06.2014 03:39
DynamicsAxSCM: Warehouse Key Performance Indicators in Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 26.06.2014 21:11
Часовой пояс GMT +3, время: 05:49.
