#1 |
emeadaxsupport: Using the new Keyword search option to create Sales Orders in Dynamics AX 2012 R3
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r3.aspx
============== In AX 2012 R3 there is a new search feature that you can use to create sales order. With this new feature you can search based on multiple options such as Sales order, Purchase order, and phone number just to name a few. The option that will be discussed in this post is Keyword. In order to use Keywords in your search you first need to define criteria to be included as keywords. I will use the type of Customer in this example as we working with creating Sales Orders.
For example let's say that you have criteria setup for Name and you need to create a Sales Order for a school but you cannot remember the actual name or the account number. However you do know that School is part of the name. When you click to create the Sales Order, select Keyword as the Search by and enter school in the search. The search will return results that have school in any of the fields you have defined in the search criteria. In my case Address is also set as search criteria, and since one of my Customers has School as part of the address, 2 results are displayed. At this point you can mark the record you want, click Select Customer in the menu bar and continue to create the Sales Order. Dave B. Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r3.aspx
#2 |
MCT
понравилось
проверил - удобная фича и даже работает
![]() К примеру, я знаю один из реквизитов товара (код, название, краткое название или какой-то другой). Раньше (до R3) я должен был: 1. открыть лукап со списком всех товаров 2. выбрать нужный столбец (при это мнужный столбец должен быть в лукапе, как известно, стандартные лукап-ы содержат скудное количество полей) 3. нажать фильтр по полю и ввести искомое значение (со звездочками) Теперь (в R3): 1. прямо в поле "код номенклатуры" (непосредственно в строке документа, без каких-либо лишних лукапов) вводим известное нам значение (часть кода, названия, краткого названия и т.д.) - без ненавистных для многих пользователей звездочек 2. система фильтрует не по одному столбцу (как раньше), а по преднастроенному списку столбцов из карточки товара (продукта) 3. если по условию найден один товар - он автоматически подставится в строку (раньше нужно было лишний раз кликать на единственную отфильтрованную запись) 4. если по условию найдено более одного товара - откроется отфильтрованный список (поддерживаются номенклатурные аналитики и даже текущие запасы показываются, некий аналог старой доброй формы "Создать строки") Такие возможности сделаны для клиента и товара.
Sometimes there is a moment as you are awakening - when you become aware of the real world around you, - but you are still dreaming. - You may think you can fly but you do better not try. |
| За это сообщение автора поблагодарили: sukhanchik (4), lev (2), Ivanhoe (3). | |
#3 |
Хорошее развитие идеи AliasFor
Ivanhoe as is.. |
| Теги |
| lookup, lookup filter, поиск, фильтр |
