Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 07.08.2014, 16:13   #1
ist is offline
ist
Upgrade to AX2012 R3
Hi Everyone,
Do I have to install Fondation Upgrade model if I have to do an upgrade from AX2012R2 CU7 to AX2012R3?
Thank you in advance.
Старый 07.08.2014, 16:49   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Yes, you do. See also Scenario: Perform in-place upgrade to AX 2012 R2 or AX 2012 R3 (Foundation Upgrade model is mentioned in the "Run AX 2012 R3 Setup on the test system" section, step 3).
Старый 07.08.2014, 22:21   #3
ist is offline
ist
Thanks a lot.
fatihdemirci: AX2012 R3 kurulum ve yenilikler Blog bot DAX Blogs 0 06.05.2014 21:12
emeadaxsupport: Issue with number sequence after upgrade to AX2012 R2 in place. Blog bot DAX Blogs 0 11.10.2013 19:11
emeadaxsupport: AX2012 Upgrades - Setting a clean AX2012 database to start with the upgrade check-list and not the Initialization check-list. Blog bot DAX Blogs 1 13.02.2013 23:47
sumitax: AX2012 – Upgrade scripts Blog bot DAX Blogs 0 01.03.2012 02:14
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
Часовой пояс GMT +3, время: 14:54.
