Старый 22.06.2014, 14:11   #1
emeadaxsupport: Things to remember after every kernel + application hotfix installation
Источник: http://blogs.msdn.com/b/axsupport/ar...tallation.aspx
Once you have installed any new kernel or application hotfix make sure to run all steps in the “Software Update Checklist” from top to bottom!
Especially important are the following points:
* Run a full X++ compilation
* Run a full CIL compilation
* Run a AOT -->  SQL server DB synchronization
* Restart all of your relevant AOS servers
emeadaxsupport: After installing application Hotfix released on KB #2786631, it is not possible to cancel Invoice in Invoice approval journal on AX 2009 SP1 RU6 or higher Blog bot DAX Blogs 0 22.08.2013 14:11
emeadaxsupport: AX 2009 Hotfix installation fails with Error 1303 - The installation has insufficient privileges to access this directory Blog bot DAX Blogs 0 09.11.2010 19:10
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
emeadaxsupport: Error during Hotfix installation - "Version string portion was too short or too long" Blog bot DAX Blogs 0 13.11.2009 21:05
Часовой пояс GMT +3, время: 17:39.
