Старый 22.06.2014, 01:19   #1
emeadaxsupport: Documentation collection: Inplace upgrade MS Dynamcis AX 2012 RTM --> AX 2012 R2 CU7
Источник: http://blogs.msdn.com/b/axsupport/ar...12-r2-cu7.aspx
Main documentation: The following 2 items explain the Inplace Upgrade process. No 1) shows the basic idea and No 2) goes even more into detail:
(Important: Please follow all the steps in No 2) exactly in the given order and plan enough time for tests)
1) http://technet.microsoft.com/en-us/l.../jj733502.aspx
2) http://www.microsoft.com/en-us/download/details.aspx?id=14599 (Note: This used to be updated about every 3-4 month, so it makes sense to check here for updates)
Best practice advices:
http://blogs.msdn.com/b/axsupport/ar...s-ax-2012.aspx
http://blogs.msdn.com/b/axsupport/ar...sfer-tool.aspx
http://blogs.msdn.com/b/axsupport/ar...e-service.aspx
http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
http://blogs.msdn.com/b/axsupport/ar...some-help.aspx
http://blogs.msdn.com/b/axsupport/ar...eceivable.aspx
http://blogs.msdn.com/b/axsupport/ar...n-updated.aspx
http://blogs.msdn.com/b/axsupport/rss.aspx?tags=ax+2012+r2
Known issues:
http://blogs.msdn.com/b/axsupport/ar...ts-to-run.aspx
http://blogs.msdn.com/b/axsupport/ar...een-added.aspx
http://blogs.msdn.com/b/axsupport/ar...-upgrades.aspx
http://blogs.msdn.com/b/axsupport/ar...-instance.aspx
http://blogs.msdn.com/b/axsupport/ar...g-upgrade.aspx
http://blogs.msdn.com/b/axsupport/ar...12-r2-cu6.aspx
http://blogs.msdn.com/b/axsupport/ar...-in-place.aspx
http://blogs.msdn.com/b/axsupport/ar...e-upgrade.aspx
http://blogs.msdn.com/b/axsupport/ar...allations.aspx
http://blogs.msdn.com/b/axsupport/ar...p-session.aspx
As an extra effort please share the following hints to your colleague Amit regarding AX object ID conflicts:
http://blogs.msdn.com/b/mfp/archive/...d-problem.aspx
mfp: AX 2012 R2 CU7 has been released! Blog bot DAX Blogs 14 26.11.2013 12:12
emeadaxsupport: AX Content: How to install CU7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 12.11.2013 01:12
emeadaxsupport: New and updated content is available for cumulative update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 27.06.2013 19:11
axaptacorner: Upgrade from Ax 2012 to AX 2012 R2 Blog bot DAX Blogs 0 18.01.2013 20:11
Часовой пояс GMT +3, время: 01:33.
