Старый 30.05.2014, 16:11   #1
gustafwesterlund: Issues with the new Plugin Registration tool
Источник: http://gustafwesterlund.blogspot.com...tion-tool.html
As you might have noticed there is a new version of the plugin registration tool out with the new version of the SDK 6.1 released in may 2014. It has gotten a nice facelift in the UI and can now be found in the Tools directory.
However, I have had some issues when working with my on-premise org (it worked fine with online). I got the following error when trying to register a step on a plugin assembly.
Unhandled Exception: System.ServiceModel.FaultException`1[[Microsoft.Xrm.Sdk.OrganizationServiceFault, Microsoft.Xrm.Sdk, Version=6.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35]]: Assembly file name (CRMKonsulterna.Modelon.Plugins.dll) is in invalid format. Only file name is allowed.
Detail:
-2147204719
2014-05-30T06:58:51.0596986Z
-2147204719
Server stack trace:
at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Microsoft.Xrm.Sdk.IOrganizationService.Create(Entity entity)
at Microsoft.Xrm.Sdk.Client.OrganizationServiceProxy.CreateCore(Entity entity)
at Microsoft.Crm.Tools.PluginRegistration.RegistrationHelper.RegisterStep(CrmOrganization org, CrmPluginStep step)
at Microsoft.Crm.Tools.PluginRegistration.StepRegistrationForm.btnRegister_Click(Object sender, EventArgs e)
I'm including it all here for searchability. I have highlighted the message that is the interesting part.
When retrying it in the older version of Plugin Registration tool, it works just fine, as long as I re-register the assemblyfile. If I keep the assembly file and try to register the step in the older version (6.0.0001.0061) I will still get the error, so I did have to unregister the entire assembly and register it all over. This also only seems to show up when registering to disk (I havn't tried registereing to GAC as I seldom use that).
Also do note that despite right clicking on the assembly-plugin and pressing "Add step" it seems to omit this information in the form for registering the step so make sure that your step is registered on the correct assembly. I got a bit confused and registered quite a few on ActivityFeeds until I noticed this.
For reference, this is for Plugin Registration Tool version 6.1.0.519 and I am testing it on CRM 2013 UR2 Onpremise.
I am also quite sure these bugs will be fixed soon by Microsoft, but it might be a good idea to keep a copy of the older Plugin registration tool just in case.
Gustaf Westerlund
MVP, CEO and owner at CRM-konsulterna AB
www.crmkonsulterna.se
East Ocean - Technical: CRM2011 Plugin Registration Tool Throw Generic SQL error Blog bot Dynamics CRM: Blogs 0 30.05.2013 13:11
Microsoft Dynamics CRM Team Blog: Using the Plug-in Registration Tool for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 14.06.2011 01:11
gustafwesterlund: IFD on Windows Server 2008 R2 problem with plugin registration Blog bot Dynamics CRM: Blogs 0 07.09.2010 19:06
Plugin Registration Tool : Server Unavailable MikeR Dynamics CRM: Разработка 5 31.03.2010 10:34
CRM DE LA CREME! CRM Manual Registration Tool- download link fixed Blog bot Dynamics CRM: Blogs 0 09.10.2009 10:05
Часовой пояс GMT +3, время: 15:40.
