Старый 01.05.2014, 20:16   #1
Clean off the illegal characters from file name
Источник: http://alexvoy.blogspot.com/2014/05/...from-file.html
When it comes to use file names, say, in saving reports on the disk or sending them as an attachment, they must conform OS restrictions.
Although we cannot rely on GetInvalidFileNameChars function due to its limitation, it is easy to create your own procedure that clean off the illegal characters from the given file name.
In my example I use a regular expression and a set of characters that should be replaced with the underscore by default.
/// Checks for invalid characters in the filename and changes them with underscore.
/// The file name value.
/// The character to use instead of illegal characters. Underscore by default.
/// valid file name
static client str makeFileNameValid(str _fileName, str 1 _char2use = "_")
str pattern = "[/:*?'|]";
str fileName;
fileName = System.Text.RegularExpressions.Regex::Replace(_fileName, pattern, _char2use);
fileName = strReplace(fileName , '\\', _char2use);
return fileName;
I used this article.
За это сообщение автора поблагодарили: Ace of Database (2).
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
DynamicsAxSCM: Import vendor catalogs: from setup to importing a sample catalog – Part 2 (Importing a sample catalog) Blog bot DAX Blogs 0 09.09.2012 20:15
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Jim Wang: Get Entity/Attribute's Display Name from CRM database Blog bot Dynamics CRM: Blogs 0 28.03.2009 01:05
Часовой пояс GMT +3, время: 09:13.
