Старый 24.03.2004, 10:54   #1
paucer is offline
paucer
? filter on a form - how?
I need add some functionality to a form, but only when filtering is enabled.
How can i check this?
Form's datasource has mathod filter(), but it seems this method isn't invoked, when user press filter shortcut button or press CTRL+F3 or filter from context menu. I tried to use prompt() method, but it isn't invoked when filtering is started via context menu. And i need do additional calculation, when the filter is enabled or is being disabled - removeFilter() works ok.
So how can I manage filtering?
At least i must know if fitering is turned on or off.
Старый 25.03.2004, 13:20   #2
rumpleteazer is offline
rumpleteazer
To intercept pressing of filter button, you should use task-method on a form. The input parameter for this method is task-event id. Filter event id is 2837, but you should better use macro Task (#taskFilter).
Example:
public int task(int _p1)
#Task
int ret;
if(_p1 == #taskFilter)
// you code handling filter-event goes here
ret = super(_p1);
Return ret;
С уважением, Rumpleteazer.
DeniZone: How to tell if a form was opened with 'Go to main table' function Blog bot DAX Blogs 0 17.02.2009 19:05
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
hariprasadp: Grid Filter while open a form in Dynamics AX Blog bot DAX Blogs 0 07.05.2008 15:05
axaptafreak: Automatically open grid filter when opening form Blog bot DAX Blogs 2 20.06.2007 18:36
Часовой пояс GMT +3, время: 02:13.
