Старый 30.08.2013, 06:12   #1
emeadaxsupport: Outlook Contact Field Synchronization with Dynamics AX 2012 R2
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
I recently ran across the need to expand fields that automatically sync from Dynamics AX 2012 R2 to Outlook contact records. It is a very time consuming and labor intense process to manually map fields on each Contact record selected for Outlook Synchronization.
Here is the scenario:
1. Business Fax is not a field synchronized from AX to Outlook through standard out-of-the-box mapping.
2. By default, the Outlook Contact card displays the Primary Number selected in AX but the Business Telephone Number field is not populated on the Outlook contact form. I want the Primary Telephone to show both on the Outlook Contact card and form as the Business Telephone Number.
Solution:
The automatic field mapping can be customized by modifying the createFieldMapping method under the smmContactPersonSynchronizationFieldMapping table.
// Primary phone  - modified so Primary Phone field in AX syncs to the Business Telephone on the Outlook record
        if (syncDirectionValid(smmOutlookContactFields::PrimaryTelephoneNumber))
            contactInfo = DirParty::primaryElectronicAddress(contactPersonEntity.getPartyRecId(), LogisticsElectronicAddressMethodType::Phone);
            if (contactInfo)
                _contactFieldRecordMap.insert(smmOutlookContactFields::BusinessTelephoneNumber, contactInfo);
 // Business Fax - this section added so Business Fax will automatically sync with the corresponding Outlook contact field
        if (syncDirectionValid(smmOutlookContactFields::BusinessFaxNumber))
            contactInfo = DirParty::primaryElectronicAddress(contactPersonEntity.getPartyRecId(), LogisticsElectronicAddressMethodType::Fax);
            if (contactInfo)
                _contactFieldRecordMap.insert(smmOutlookContactFields::BusinessFaxNumber, contactInfo);
End Result:
Of course, this may not meet your specific needs but it provides an example of what is possible through a little customization.
emeadaxsupport: New and updated content is available for cumulative update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 27.06.2013 19:11
DAX: How to gain additional value from the Microsoft application platform with Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 3 21.06.2013 15:16
emeadaxsupport: New installable help AX 2012 R2 Blog bot DAX Blogs 0 21.02.2013 02:13
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 18:42.
