Старый 23.07.2013, 21:12   #1
axperf: Improving SSRS Report Performance with Hybrid of Line-based and Set-based Processing – Part 4
Источник: http://blogs.msdn.com/b/axperf/archi...ng-part-4.aspx
This pattern applies to a wide range of reports. It is the most applied pattern so far as based on our experience. The idea is to isolate line-based code to the minimum and leverage set-based operations to the maximum at the same time. Here is a list...(read more)
axperf: Improving SSRS Report Performance with Set-Based Operations - part 1 Blog bot DAX Blogs 0 20.07.2013 09:18
crminthefield: Improving Dynamics CRM Report Performance – Part 1 “The Basics” Blog bot Dynamics CRM: Blogs 0 28.01.2013 20:13
ax-erp: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 07:55.
