Старый 26.11.2012, 18:11   #1
Malaysia: Building a tree lookup
Источник: http://axmas.blogspot.com/2012/11/bu...ee-lookup.html
1. In the AOT, create a new form named BudgetModelLookup. Set its design properties
as follows:
Property Value
Frame Border
WindowType Popup
2. Add a new Tree control to the design, with the following properties:
Property Value
Name ModelTree
3. Add the following line to the form's class declaration:
BudgetModelTree budgetModelTree;
4. Override the form's init() method with the following code:
public void init()
FormStringControl callingControl;
callingControl = SysTableLookup::getCallerStringControl (this.args());
super();
budgetModelTree = BudgetModelTree::construct(ModelTree, callingControl.text());
budgetModelTree.buildTree();
5. Override the mouseDblClick() and mouseUp() methods of the ModelTree control
with the following code, respectively:
public int mouseDblClick(int _x, int _y, int _button, boolean _ctrl, boolean _shift)
int ret;
FormTreeItem formTreeItem;
BudgetModel budgetModel;
ret = super(_x, _y, _button, _ctrl, _shift);
formTreeItem = this.getItem(this.getSelection());
select firstOnly SubModelId from budgetModel
where budgetModel.RecId == formTreeItem.data();
element.closeSelect(budgetModel.SubModelId);
return ret;
public int mouseUp(int _x, int _y, int _button, boolean _ctrl, boolean _shift)
int ret;
return 1;
6. The form should look similar to the following screenshot:
7. In the AOT, open the BudgetModel table, and change its lookupBudgetModel()
public static void lookupBudgetModel(FormStringControl _ctrl, boolean _showStopped = false)
Args args;
Object formRun;
args = new Args();
args.name(formStr(BudgetModelLookup));
args.caller(_ctrl);
formRun = classfactory.formRunClass(args);
formRun.init();
_ctrl.performFormLookup(formRun);
8. To see the results, open Budgeting | Common | Budget register entries. Start
creating a new entry by clicking on the Budget register entry button in the action
pane, and expand the Budget model lookup:
Malaysia: Using a form for building a lookup Blog bot DAX Blogs 0 26.11.2012 11:11
Malaysia: Building a selected/available list Blog bot DAX Blogs 0 14.11.2012 14:11
Malaysia: Using a tree control Blog bot DAX Blogs 0 08.11.2012 11:11
Malaysia: Building a dynamic form Blog bot DAX Blogs 0 07.11.2012 17:11
Malaysia: Lookup Blog bot DAX Blogs 0 30.10.2012 15:11
Часовой пояс GMT +3, время: 16:22.
