Старый 17.11.2012, 11:12   #1
axtadka: Adding a field on dialog by addfield() method, when the type of EDT is known at run time, in Dynamics AX 2009
Источник: http://axtadka.blogspot.com/2011/01/...-addfield.html
Possible situations when:
1.EDT type is fixed and is known at design time.
public Object dialog()
DialogRunbase dialog = super();
dlgTransDate = dialog.addField(typeid(CustAccount));
return dialog;
2. EDT Name is known in some situation.
DialogRunbase dialog;
Str edtName = “CustAccount”;
dialog = super();
dialog.addField(new sysDictType(new Dictionary().typeName2Id(edtName)).extendedTypeId());
return dialog;
3. EDT Name is not known at design time, but is known at Run time from a table field.
str edtName;
dictField dictField;
dialog = super();
dictField = new DictField(tablenum(CustTable),fieldnum(CustTable, AccountNum));
edtName = extendedTypeId2name(dictField.typeId());
//Get the EDT information from field of a table. Here Field AccountNum from table CustTable
//has been taken for example.
dialog.addField(new sysDictType(new dictionary().typeName2Id(edtName)).extendedTypeId());
return dialog;
dax-lessons: How to handle SSRS reports which will take long time to run with the messages to the user [Dynamics AX 2012– preRunValidate() method] Blog bot DAX Blogs 0 22.05.2012 02:12
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating with multiple Dynamics AX 2009 instances (AOS) and/or if currency translation and eliminations are required (Part 4 of 7) Blog bot DAX Blogs 0 07.01.2012 03:18
Часовой пояс GMT +3, время: 13:26.
