Старый 09.08.2012, 19:12   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Temporary Tables (AX 2012)
Источник: http://blogs.msdn.com/b/axsupport/ar...s-ax-2012.aspx
Set/Link Data on
In Ax 2012, the Temporary property on tables was
replaced with a new property: TableType, which has three possible
values:
  • Regular - a standard
    physical table
  • InMemory - the type
    of temporary table which existed in the previous versions of Dynamics Ax.
    Such tables are held in memory and written to a local disk file once they
    grow beyond a certain point
  • TempDB - a new
    option in Ax 2012. They are "physical" temporary tables held in
    the SQL Server database.
The new TempDB tables operate in a similar manner to InMemory
tables but support more features of standard physical tables:
  • More powerful
    joins with physical tables are possible, and are properly supported by the
    database
  • Can be
    per-company or global
  • Support for
    normal tts transactions
To create
a new instance link (populating data/copying reference) from one table instance
variable to the other with Temporary type tables:
Code Examples:
Open AOT/Data Dictonary/Tables
Create a New table, name it "TestTmp"
Expand it, create a new field of type string and name it "Id"
1)
InMemory:
- Set
the "TestTmp" table "TableType" property to
"InMemory", save
- Create
and run following job:
static void TestTmpInMemory(Args _args)
TestTmp tmp1, tmp2;
tmp1.Id = "1000";
tmp1.insert();
tmp2.setTmpData(tmp1);
info("Table
type: " + enum2Str(tmp1.getTableType()));
info("tmp1
data begin: ");
while
select tmp1
info(" Id " + tmp1.ID);
info("tmp1
data end.");
info("tmp2
data begin: ");
while
select tmp2
info(" Id " + tmp2.ID);
info("tmp2
data end.");
2)
TempDB:
- Set
the "TestTmp" table "TableType” property to "TempDB",
save
- Create
static void TestTmpTempDB(Args _args)
TestTmp tmp1, tmp2;
tmp1.Id = "1000";
tmp1.insert();
tmp2.linkPhysicalTableInstance(tmp1);
info("Table
info("tmp1
data begin: ");
while
select tmp1
info("tmp1
data end.");
info("tmp2
data begin: ");
while
select tmp2
info("tmp2
data end.");
Author: Mansour Yahya Mohammad
Date: 9/8-2012
axdaily: SQL temporary tables in AX 2012 Blog bot DAX Blogs 25 06.05.2011 10:18
Часовой пояс GMT +3, время: 23:14.
