Старый 27.04.2012, 16:11   #1
25,497 / 847 (79) +++++++
ax-erp: The backup set holds a backup of a database other than the existing database
Источник: http://microsoft-dynamics-ax-erp.blo...-database.html
This error message appear when I tried to restore an SQL 2K SP4 db into SQL 2005, using SQL Server Management Studio.
Although I have specified overwrite existing database, the error message still appear.
So I run transact-sql statement instead :
restore filelistonly
from disk = 'D:\SQL Backup\sourceDB.bak'
GO
--This will show the logical file name needed in the operation below
restore database targetDB
WITH MOVE 'sourceDB_Data' TO 'D:\SQLDATA\targetDB_Data.MDF',
MOVE 'sourceDB_Log' TO 'D:\SQLDATA\targetDB_Log.ldf',
REPLACE,STATS
GO
-- The option with replace is mandatory as it will overwrite existing database. With stat will show the operation progress
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 07:59.
