Старый 26.04.2012, 19:11   #1
Gareth Tucker: Social Integration for Microsoft CRM 2011 with Parrot
Источник: http://gtcrm.wordpress.com/2012/04/2...1-with-parrot/
Want to integrate your company’s Twitter, Facebook and LinkedIn feeds into your Microsoft CRM system so you can view one consolidated feed, react to social conversations by creating CRM Leads, Contacts and Cases, and post your own social messaging to all 3 channels in 1 hit?   If that’s you, then Webfortis have an Add-on for Microsoft CRM that you should take a look at.
Here’s an overview…
Installation and Configuration
Webfortis offer a free 2-user license of Parrot so to trial Parrot you simply submit your details here, then download and install:
Parrot users are licensed separately from CRM, you can have 100 CRM users but only 2 of them activated for access to Parrot,  so the 2 user limit won’t be a problem.
The product is provided as a CRM Solution file that you simply import into your CRM system via CRM’s Import Solutions feature.  What you then see is a Parrot menu option added to  your Workplace:
Next step is configuration.  Parrot wants access to your LinkedIn, Twitter and Facebook accounts so it can download your feeds and post on your behalf (when you request it to).  So we click on the Parrot Settings button on the Ribbon and add our Accounts:
Jump back to the Parrot Timeline screen and you can now activate those new accounts via ribbon buttons:
Features
Once you have authorised Parrot to access your social networks those feed will now appear on Parrot’s Timeline display.  You will all of your Twitter, Facebook and LinkedIn feeds consolidated in the 1 view for easy monitoring:
So Feature #1 is this consolidated view of your social networks inside your CRM system.
Feature #2 is the ability to post to all of your social networks at the same time, from Microsoft CRM.   The post composer sits above the Timeline.  You can easily toggle which of your social networks you want your message to post to and you can see the number of characters remaining (constrained to the lowest limit of the networks selected):
Feature #3 is the ability to search LinkedIn, Facebook and Twitter’s feeds for keywords.  Search results appear in Tabs and you can have several on the go and can pin them for on-going reference:
Now so far, apart from having all of this sit inside you CRM system, we are not seeing anything too different from what Hootsuite offers, and Hootsuite does it better:
Except, we are in CRM, and where that really makes a difference is with these little buttons here:
That’s right, with a click of a button you can create a new Lead, Case, Contact or Account in CRM based on a social media post.   That’s Feature #4 and I think its kind of interesting.
If we create a Lead for Mark Smith’s LinkedIn post we get a CRM Lead record like this:
The Lead record retains an association back to the social media entity it originated from – in this case the profile of an Individual on LinkedIn – and this linkage is leveraged on the Lead form to provide an integrated view of that profile, in CRM:
That’s enough from me for today.  Hopefully  this has provided you with a useful overview of the Webfortis offering.  I recommend having a look at Parrot.  Its probably not going to do enough for Enterprise customers but it does aid you in thinking about your social strategy and paints a useful view of the sort of integration that is possible between Social and Microsoft CRM.
(p.s. How cool is enterprise Owl!)
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
Gareth Tucker: Installing the Customer Care Accelerator (CCA) for CRM 2011 Blog bot Dynamics CRM: Blogs 3 23.12.2011 09:16
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Online Test Drive Guide Blog bot Dynamics CRM: Blogs 0 05.08.2011 20:13
Gareth Tucker: Getting Started with CRM 2011 Online Fetch XML Reporting Blog bot Dynamics CRM: Blogs 0 19.05.2011 23:13
Часовой пояс GMT +3, время: 14:48.
