Старый 21.04.2012, 13:12   #1
emeadaxsupport: AX2012 POS: Adding a new line is slow
Источник: http://blogs.msdn.com/b/axsupport/ar...e-is-slow.aspx
Issue:
When scanning an Item in POS the insert into the line grid seem a bit slow.
Solution:
In the POS.EXE.CONFIG file change the Pooling to true
C:\Program Files (x86)\Microsoft Dynamics AX\60\Retail POS\POS.EXE.CONFIG file
Estimated improvement:
30-50% better performance
Suggested environment for optimal performance on POS:
Hardware requirements for a
point-of-sale computer
The following table lists the
hardware requirements for a point-of-sale register. The requirements apply
whether or not an offline database is installed on the register computer. Each register
computer that will be used to process card payments must also have Internet
access.
Item
Requirement
Processor
Minimum: Intel/AMD processor in
http://www.cpubenchmark.net/high_end_cpus.html
Recommended: Intel/AMD
Processor Top 15
http://www.cpubenchmark.net/common_cpus.html
RAM
Minimum: 2 GB
Recommended: 4 GB
Available hard disk space
Minimum: 30 GB 7200 rpm
Recommended: 30 GB SSD
Monitor
Super VGA (1024 × 768) or
higher-resolution monitor or a touch screen monitor
Mouse
Microsoft mouse or compatible
pointing device
Author: Kim Truelsen
Date: 21/4-2012
emeadaxsupport: AX2012 and AX2009 or AX4 side by side - AOS performance counters overwritten Blog bot DAX Blogs 0 13.03.2012 18:11
emeadaxsupport: Retail: How to access multiple POS from one machine Blog bot DAX Blogs 0 26.08.2011 21:13
emeadaxsupport: Buttons in the POS layout are not all localized. Blog bot DAX Blogs 0 25.08.2011 19:11
emeadaxsupport: When an expense line is rejected the remaining lines cannot be approved Blog bot DAX Blogs 0 26.05.2010 12:05
emeadaxsupport: When an expense line is rejected the remaining lines cannot be approved Blog bot DAX Blogs 0 20.05.2010 20:06
Часовой пояс GMT +3, время: 15:11.
