Старый 23.03.2012, 04:25   #1
Microsoft Dynamics CRM Team Blog: Read-optimized forms
Источник: http://blogs.msdn.com/b/crm/archive/...zed-forms.aspx
As Microsoft Dynamics CRM moves into the future by enabling information workers to access information across many devices and networks—environments in which time-to-load and consumption are the key success factors—we’re focusing more than ever on providing a fast-loading, consumption-oriented user experience. This focus is particularly helpful for people who use Microsoft Dynamics CRM primarily to consume data, rather than to edit or update records.
To further these goals, in Update Rollup 7 we’re introducing a new feature called read-optimized forms.
A read-optimized form displays a record very quickly. We achieved this by trimming the record to its bare essentials: just the data, with no ribbon, Web Resources, or form scripts.
Need to edit a read-optimized form? Editing the record is just a click away.
In Update Rollup 7, read-optimized forms are disabled by default. Because we’re introducing a brand-new experience in viewing records, we didn’t want to surprise you by turning it on as the default experience. We also know that some of you have form customizations using scripts and Web Resources. We’ve made sure that those experiences continue to work as expected. We plan to continue refining the read-optimized form experience in future releases, so that read-optimized forms will eventually become the default record-viewing experience.
In this post, I want to introduce you to read-optimized forms. Here are the things that I’m going to cover:
• Read-optimized form details
• Switching to the full edit mode
• How to enable read-optimized forms
• When will you see a read-optimized form vs. an editable form?
Read-optimized forms shorten the time needed to open a record by stripping the form down to its bare essentials. A read-optimized form:
• Displays all fields, notes, IFrames, and sub-grids that are visible by default.
• Honors all form- and field-level security configurations.
• Does not display the ribbon or allow editing a record.
• Does not display form navigation.
• Does not display embedded Web Resources.
• Does not execute form scripts.
The following screenshots show read-optimized forms for a sample Account.
Notes
If you’ve added notes to your record, you can view them in the read-optimized form. However, you’ll have to switch to the edit mode to add a new note or to edit your existing notes.
Sub-grids
Most of us have related records that show up as sub-grids in the main form. You’ll be able to view these sub-grids in the read-optimized form, and all common sub-grid actions like refresh, sorting, paging, and search will work. Also, if you have a sub-grid represented as a chart, it will render properly in the read-optimized form. However, since there isn’t a ribbon on read-optimized forms, ribbon actions on the sub-grid won’t be available.
IFrames
Some of us get data from external systems into Microsoft Dynamics CRM by using an IFrame, and seeing that IFrame in the context of your CRM record is very important to us. Because we realize the importance of your IFrames, we’ve enabled them on read-optimized forms. This is one of the places where a read-optimized form differs from the Outlook reading pane. However, if your IFrame calls in to the client API to get some form data, you might get errors on the form because read-optimized forms don’t have client API support.
Activity Feeds and Image Web Resources
A read-optimized form will render properly if it has Activity Feeds and/or image Web Resources, but if the form has other Web Resources or scripts, editable form will render automatically. In Update Rollup 7, Activity Feeds and image Web Resources don’t render; to view them, you must switch to the edit mode. By the way, we plan to change this behavior in our next major release, and at that time we expect Activity Feeds and image Web Resources to work in read-optimized forms. Today, however, this is what the user will see when viewing Activity feeds or image Web Resources in a read-optimized form:
Editing a record that’s in read-optimized form is just one click away. A user can quickly switch to the edit mode in two ways:
1) On an open read-optimized form, click the Edit button in the toolbar.
2) Before opening a record, on the record grid, select a record and then click the Edit button.
The default behavior when Update Rollup 7 ships will be to turn off read-optimized forms for all new and existing organizations. The admin or user will have to explicitly turn on the feature to enjoy the capabilities of read-optimized forms.
Admin settings
The admin can set the form mode at an Org level, and also select individual users to use read-optimized forms.
At the Org level, the admin can set the default form mode for all users by clicking Settings, Administration, System Settings, and then going into the Form mode area. Here, the admin also can control whether to give users the option to configure the form mode, or not.
• If the admin selects Edit as the default form mode and disallows user configuration, users will always get editable forms.
• If the admin enables users to change their default form viewing mode, all of their forms will load in the mode that they select (Read-Optimized or Edit). This individual setting overrides the organization default setting for that user.
The admin can also select just a few users and change their form viewing default (for example, mobile salespeople who prefer to use read-optimized forms). This sets the default form mode for those users, and is also reflected in their User setting (Set Personal Options dialog). These users can change the form viewing mode if they want to.
User setting
By default, users will get the organization default as their form viewing mode. However, if the user chooses a specific form mode, all of their forms will load up in the mode they select (Read-Optimized or Edit). The user setting will always override the Org setting for that user.
Many of you have form customizations that involve Web Resources and custom scripts, and we made sure that we didn’t break them. Because read-optimized forms don’t support Web Resources or custom scripts, we detect if your form has these components and then load the editable form automatically for you—ignoring the org/user settings.
Information for developers is available in the Microsoft Dynamics CRM 2011 SDK topic: Design Considerations for Read Only Forms.”
I look forward to hearing your feedback on read-optimized forms. Just remember that you need to enable the read-optimized mode in order to use them!
Anusha Shankar
Microsoft Dynamics CRM Team Blog: Fast, Efficient Growth for Project Management Solution - Case Studies Blog bot Dynamics CRM: Blogs 0 01.02.2012 03:18
Microsoft Dynamics CRM Team Blog: Driving Success with the New Microsoft Dynamics Marketplace! Blog bot Dynamics CRM: Blogs 0 28.01.2011 00:12
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM E-mail Router Blog bot Dynamics CRM: Blogs 0 09.01.2009 06:03
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Interviews and Screencasts Blog bot Dynamics CRM: Blogs 0 23.07.2008 03:18
Часовой пояс GMT +3, время: 03:58.
