Старый 10.03.2012, 16:12   #1
dynamicsaxbi: Collections: Report Developer Resources
Источник: http://blogs.msdn.com/b/dynamicsaxbi...resources.aspx
Dynamics AX 2012
This article contains a list of helpful resources for Microsoft Dynamics AX 2012 report developers.
SQL Server Reporting Services - Links to high level Reporting Services content and developing with Reporting Services.
Planning and Architecture - Describes the architecture of the reporting framework in Microsoft Dynamics AX.
Install Reporting Services extensions and configuring SQL SSRS 2008 - Describes how to install the extensions and deploy the reports included with Microsoft Dynamics AX.
Developing Reports for Microsoft Dynamics AX in Visual Studio - Describes the Microsoft Dynamics AX model-based approach for creating reports using the Microsoft Visual Studio development environment.
Reporting User Experience Guidelines - Provides guidelines for creating consistent layouts with different types of reports and charts in Microsoft Dynamics AX 2012.
Microsoft Dynamics AX 2012 White Paper: Report Programming Model - Describes the programming model to use with the Microsoft Dynamics AX reporting framework that is built on the SysOperation framework.
Working with Tablix Data Regions - Use the Tablix data region to display fields from a dataset either as detail data or as grouped data in a grid or free-form layout.
Adding Links to a Report - How to add navigational links in a Microsoft Dynamics AX report to other reports, Enterprise Portal pages, and forms in the Microsoft Dynamics AX client.
Debugging a Report Data Provider Class – Special setup instructions are required when debugging across managed and IL code.
Microsoft Dynamics AX 2009 White Paper: Print Management Guide – Describes print management, and how it gives users specialized control of print settings for selected Microsoft Dynamics AX reports.
Microsoft Dynamics AX 2012 and 2009 Reference: Report List - Use this spreadsheet to find a report similar to your scenario so that you can see the implementation details in the developer workspace.
How to engage with customer support
Microsoft Partner Network: https://partner.microsoft.com/US/40074177
--or—
Dynamics Support: https://mbs.microsoft.com/partnersource/support
dynamicsaxbi: Thoughts on the AX Technical Conference and A Preview of SSRS Report Development in Dynamics AX 2012 Blog bot DAX Blogs 1 07.02.2011 14:59
Microsoft Dynamics CRM Team Blog: Report Scheduling with Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 07.01.2011 20:11
Microsoft Dynamics CRM Team Blog: Using SQL Server 2008 to Improve Report Resources Management Blog bot Dynamics CRM: Blogs 0 28.10.2009 00:06
Microsoft Dynamics CRM Team Blog: Reports for CRM 4.0 using SQL Server 2008 and Report Builder 2.0 Blog bot Dynamics CRM: Blogs 0 11.11.2008 08:05
Часовой пояс GMT +3, время: 02:23.
