Старый 15.01.2012, 05:17   #1
equalized: Dynamics Ax printing logo’s from batch
Источник: http://www.kevinroos.be/2011/01/dyna...os-from-batch/
Hi,
*Edit Microsoft has released a fix for this problem contact support for this*
As all of you know the Image class in Dynamics Ax 4.0 and 2009 can only run on client. This poses a problem when you want to print for example invoices with your company logo on it. Having this found out I went to look for an alternative!
I’ve added this code to the top of the PDFViewer class in the writeBitmap(OutputBitmapField _field, OuputSection _section) method
if( isRunningOnServer() && _field.name() == #FieldLogo) { this.BLOGWriteBitmapOnServer(_field,_section); super(_field, _section); return; }
For the method BLOGWriteBitmapOnServer(OutputBitmapField _field, OuputSection _section) I have copied everything from the writeBitmap and started by replacing the Image object with a System.Drawing.Image object, you can make a company parameter for this file path.
img = System.Drawing.Image::FromFile(imgStr);
After compiling there are a few errors witch I’ve corrected and ended up with this code.
<div class="wp_syntax"><div class="code">public void BLOGWriteBitmapOnServer(OutputBitmapField _field, OuputSection _section) { #File BinData bin = new BinData(); //Image img; container data, imgInfoData; str s; real x1,x2, y1,y2; Struct br; int imageObjectNo = 0; int newwidth, newheight; real pdfPreviewScale = 0.8; boolean generateXImage = false; container c; str fn; FileIOPermission writePermission; FileIOPermission readPermission; boolean grayScale = false; System.Drawing.Image img; str imgStr; int widthTemp, heightTemp; CompanyInfo companyInfo = companyInfo::find(); ; new InteropPermission(InteropKind::ClrInterop).assert(); imgStr = companyInfo.BLOGCompanyLogoFile; br = this.boundingRectTwips(currentPage, _section, _field); x1 = br.value('x1'); y1 = br.value('y1'); x2 = br.value('x2'); y2 = br.value('y2'); if (_field.type() == 10) // resourceId, DB_RESId { //img = new Image(_field.resourceId()); img = System.Drawing.Image::FromFile(imgStr); if (resourceIdImageMap.exists(_field.resourceId())) imageObjectNo = resourceIdImageMap.lookup(_field.resourceId()); else { imageObjectNo = this.nextObjectNo(); resourceIdImageMap.insert(_field.resourceId(), imageObjectNo); generateXImage = true; } if (debugLevel >= 1) info ('Image in resource ' + int2str(_field.resourceId())); } else if (_field.type() == 7) // queue { c = _field.value(); if (c) { //img = new Image(c); img = System.Drawing.Image::FromFile(imgStr); imageObjectNo = this.nextObjectNo(); } generateXImage = true; if (debugLevel >= 1) { if (img) info ('Image in container'); else info ('No image in container'); } } else // string containing filename { //img = new Image(_field.imageFileName()); img = System.Drawing.Image::FromFile(imgStr); if (stringImageMap.exists(_field.imageFileName())) imageObjectNo = stringImageMap.lookup(_field.imageFileName()); else { imageObjectNo = this.nextObjectNo(); stringImageMap.insert(_field.imageFileName(), imageObjectNo); generateXImage = true; } if (debugLevel >= 1) info ('File is ' + _field.imageFileName()); } if (img) { if (generateXImage) { fn = System.IO.Path::GetTempFileName(); widthTemp = img.get_Width(); heightTemp = img.get_Height(); img.Save(fn); // revert previous assertion CodeAccessPermission::revertAssert(); // assert read permissions readPermission = new FileIOPermission(fn, #io_read); readPermission.assert(); // BP deviation documented (note that the file io assert IS included above) bin.loadFile(fn); data = bin.getData(); // Get rid of the temporary file. //WinAPIServer::deleteFile(fn); CodeAccessPermission::revertAssert(); new InteropPermission(InteropKind::ClrInterop).assert(); System.IO.File::Delete(fn); if (bitmapEncode85) s = bin.ascii85Encode(); else s = BinData::dataToString(data); objectOffsetMap.insert(imageObjectNo, binBuffer.size()); this.appendTextToBuffer(int2str(imageObjectNo) + <span style="color: #ff0000;">' 0 obj
equalized: Dynamics Ax printing logo’s from batch Blog bot DAX Blogs 0 22.04.2011 17:11
Часовой пояс GMT +3, время: 11:40.
