Старый 11.01.2012, 14:11   #1
palleagermark: Sample file import with StreamReader
Источник: http://palleagermark.blogspot.com/20...eamreader.html
Here is one example of how you can import files with .NET's StreamReader:
static void ImportWithStreamReader(Args _args)
    Filename                filename = @'C:\Temp\importme.txt';
    System.IO.StreamReader  reader;
    System.String           line;
    InteropPermission       interopPermission;
    interopPermission = new InteropPermission(InteropKind::ClrInterop);
    interopPermission.assert();
    reader = new System.IO.StreamReader(filename,
                                       System.Text.Encoding::get_UTF8());
    line = reader.ReadLine();
    while (!System.String::IsNullOrEmpty(line))
        // Do something with line
    reader.Close();
    reader.Dispose();
If you can work with the file as on big chunk of text you can get away with just reading once, using the ReadToEnd method.
Read more about StreamReader on MSDN.
Последний раз редактировалось Poleax; 11.01.2012 в 17:14.
Microsoft Dynamics CRM Team Blog: Create Sample Data for your Solution Blog bot Dynamics CRM: Blogs 0 01.12.2011 05:14
Trace Parser. Error: Incorrect or missing MOF file, import is not available. Poleax DAX: Администрирование 6 13.05.2011 10:43
Microsoft Dynamics CRM Team Blog: Creating Custom Sample Data for CRM 2011 - Advanced Blog bot Dynamics CRM: Blogs 0 30.04.2011 01:13
Microsoft Dynamics CRM Team Blog: Creating Custom Sample Data for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 07.01.2011 03:15
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Часовой пояс GMT +3, время: 00:12.
