Старый 15.12.2011, 07:12   #1
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 R2 SP1 with Dynamics AX
Источник: http://blogs.technet.com/b/dynamicsa...namics-ax.aspx
Dynamics AX Sustained Engineering is proud to announce the following compatibility between the released versions of Dynamics AX and SQL Server 2008 R2 SP1 :
Microsoft Product
Dynamics AX Version
Dynamics AX 2009 SP1 and Dynamics AX 2012
(32 bit and 64 bit mode)
The System requirements of Dynamics AX 2009 and AX 2012 are in the process of being updated on Customer Source and Partner Source.
Follow the Dynamics AX Sustained Engineering blog for the latest updates on the above. For further information, feel free to contact daxsecom@microsoft.com
Dynamics AX Sustained Engineering: New Compatibility Testing Results - March 2010 Blog bot DAX Blogs 1 08.04.2011 10:11
dynamics-ax: Dr. BI Tip: SQL Server 2008 R2 & Report Builder 3 for AX 2009 Blog bot DAX Blogs 0 31.03.2011 18:11
Мир CRM: Улучшение Dynamics CRM 4.0 производительности и безопасности данных под SQL Server 2008 Blog bot Dynamics CRM: Blogs 0 03.02.2009 02:07
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
Часовой пояс GMT +3, время: 05:26.
