Старый 10.11.2011, 04:19   #1
Microsoft Dynamics CRM Team Blog: How to Add a Record Wall to a Form
Источник: http://blogs.msdn.com/b/crm/archive/...to-a-form.aspx
If you are an existing CRM user who has created multiple main application forms on some entities before you enable the entities for Activity Feeds, you may find that enabling Activity Feeds for them won’t add the Record Wall control to the forms of the entity which has multiple forms. This blog walks you through the steps of how to add the Record Wall control to such entities’ chosen forms.
Pre-condition:
  • You have multiple forms on an entity, e.g. Account.
  • You have installed the Activity Feeds Solution. With this condition, you are assumed to have at least system customizer privilege.
  • You have enabled Activity Feeds for Account. There is no Record Wall on any of the Account’s main application forms because this entity has multiple main application forms.
What you need to do:
  • Following the instructions step by step in order to add Record Wall to one of more forms of Account.
Post-condition:
  • Record Wall is enabled on any chosen Account forms.
1. Launch one of the Account entities and choose the form from the form selector the one that you want to have a Record Wall.
2. Click Customize Ribbon and click Form to launch FormEditor
3. Click on Insert -> Tab -> One Column to launch Tab Properties dialog
4. In the Tab Properties dialog, set the follow values
4.1 Name= tab_recordwall (Name has to be exact same as tab_recordwall)
4.2 Label = Record Wall
4.3 You can uncheck the “Expand this tab by default”
5. Click Events Tab and add msdyn_/ActivityFeeds.Form.js
5.1 Expand Form Libraries
5.2 Add -> msdyn_/ActivityFeeds.Form.js
6. Adding the Event Handlers
6.1 Click on Event Handlers
6.2 Add -> Details
6.2.1 Select msdyn_/ActivityFeeds.Form.js
6.2.2 Function = ActivityFeeds.Form.CustomizationUtils.updateRecordWallRenderingState
6.2.3 Enabled = Checked
6.2.4 Parameters -> Check the Pass execution context as first parameter and Click Ok
7. Click OK to persist Tab properties settings and go back to FormEditor.
8. Select the Record Wall Tab and double click the Section to launch the Section Properties dialog
8.1 Select Formatting -> One Column
8.2 Click OK to persist settings and dismiss the Section Properties dialog
9. In FormEditor, click on the Web Resource in the Insert Ribbon
10. Choose msdyn_/RecordWall.htm as the Web Resource in the lookup.
10.1 Select the Web resource = msdyn_/RecordWall.htm
10.2 Name= Record Wall
10.3 Check Pass record object-type code and unique identifier as parameters
11. Set the Web Resource formatting
11.1 Click on Formatting Tab
11.2 Number of Rows = 15
11.3 Click OK to persist settings and dismiss the Add Web Resource dialog
12. In the FormEditor, make sure that the Record Wall Tab is collapsed
13. Save and Publish Form
14. Go back to the Account Entity grid and launch the entity page of an Account entity. Choose the form you just modified, you will see that record wall is added to the form.
Zhen Zhang
Microsoft Dynamics CRM Team Blog: Building Your Business Hub: Using the Power of Social for a More Productive Enterprise Blog bot Dynamics CRM: Blogs 3 28.10.2011 18:59
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM’s Mashable Ecosystem to Change Customer Care Market? I think So… Blog bot Dynamics CRM: Blogs 0 20.10.2011 03:24
Microsoft Dynamics CRM Team Blog: Migrating Customizations to Microsoft Dynamics CRM 2011 Online Blog bot Dynamics CRM: Blogs 0 18.04.2011 23:11
jodonnell: Microsoft Dynamics CRM 2011 Product Team feels the need for speed Blog bot Dynamics CRM: Blogs 0 18.02.2011 10:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Online Upgrades Blog bot Dynamics CRM: Blogs 0 12.02.2011 00:11
Часовой пояс GMT +3, время: 07:54.
