Старый 04.11.2011, 17:12   #1
palleagermark: Call a BOF service with a caller record
Источник: http://palleagermark.blogspot.com/20...er-record.html
If you need to call a Business Operations Framework (BOF) service with a caller record, like you'd often do for a RunBase job, you must create a custom SysOperationServiceController to get the record argument passes from the service controller to an applicable data contract.
A good example from standard AX can found in the PurchFinalizeServiceController class.
Another example can be found here: http://www.artofcreation.be/2011/08/...icecontroller/
palleagermark: Changing AOS service name Blog bot DAX Blogs 0 08.09.2011 19:11
Gareth Tucker: Call Centre Optimised CRM–An Example Solution Blog bot Dynamics CRM: Blogs 0 07.09.2011 17:11
palleagermark: Fun observation about BOF dialogs Blog bot DAX Blogs 0 05.09.2011 18:11
DynamicsAxSCM: Service products in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 2 02.06.2011 13:36
palleagermark: Saving the reference to a unique record as a string Blog bot DAX Blogs 0 20.10.2008 11:05
Часовой пояс GMT +3, время: 14:41.
