Старый 02.11.2011, 04:17   #1
crminthefield: Caveats for Setting the Maximum File Size limits for attachments in CRM 2011
Источник: http://blogs.msdn.com/b/crminthefiel...-crm-2011.aspx
CRM 2011 has a configurable setting where you can set the “Maximum file size limit for attachments”. This is under the Email tab of the System Settings (see screenshot below).
Although this setting is under the Email tab of System Settings, it limits the size of files for the following –
  • File attachments of email messages
  • File attachments of Notes
  • Web Resources
If you set the Maximum file size to 0, it will restrict you from:
  • Promoting emails with attachments to CRM
  • Uploading attachments (to the Notes entity) in CRM
  • Errors when trying to create a Web Resource
  • Error when importing a Solution that contains a Web Resource. You will get an error that says “Web Resource content size is too big”
Per this MSDN article (http://msdn.microsoft.com/en-us/library/8c947e83-6765-41d9-b4b7-c078a68257eb), here is a brief description of this setting –
The maximum size of files that can be uploaded is determined by the Organization.MaxUploadFileSize property. This property is set in the E-mail tab of the System Settings in the application. This setting limits the size of files that can be attached to email messages, notes, and Web resources. The default setting is 5MB.
crminthefield: Microsoft Dynamics CRM 4.0 and 2011 Update Rollup Release Dates, Build Numbers, and Collateral Blog bot Dynamics CRM: Blogs 0 24.08.2011 02:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Online Test Drive Guide Blog bot Dynamics CRM: Blogs 0 05.08.2011 20:13
crminthefield: Microsoft Dynamics CRM 2011 Custom Contact Entry Website using Early-Bound entity Classes. Blog bot Dynamics CRM: Blogs 0 04.06.2011 08:16
crminthefield: How to Create a Simple Webpage Leveraging The CRM 2011 IOrganizationService Web Service Blog bot Dynamics CRM: Blogs 0 19.05.2011 02:11
Часовой пояс GMT +3, время: 21:14.
