Старый 17.10.2011, 20:11   #1
dynamicsaxtraining: Get “available physical” values for specific item+dimensions per batch
Источник: http://www.dynamicsaxtraining.com/kn...ions-per-batch
Hi! Use the following code to get On-hand values for specific item + dimensions (warehouse, configuration, size and color) per warehouse, location, pallet, batch.
Set required ItemId and inventDim (inventDim should contain warehouse, configuration, size and color values).
static void availPhysical(Args _args)
    InventSum                       inventSum;
    InventSumDelta                  inventSumDelta;
    InventDim                       sumInventDim;
    ItemId                          itemId      = 'ItemId_Here';
    InventDim                       inventDim   = InventDim::find('ItemInventDim_Here');
     WMSLocation                     wmsLocation;
     createdTransactionId            ttsId;
     while select sum(AvailPhysical)
    from inventSum
    where (inventSum.ItemId == itemId) &&
          (!inventSum.Closed) && (!inventSum.ClosedQty) &&
          (inventSum.AvailPhysical != 0)
     join sumInventDim
    group by InventLocationId, wMSLocationId, wMSPalletId, InventBatchId
    where (sumInventDim.InventDimId      == inventSum.InventDimId) &&
          (sumInventDim.InventLocationId == inventDim.InventLocationId) &&
          (sumInventDim.configId         == inventDim.configId) &&
          (sumInventDim.InventSizeId     == inventDim.InventSizeId) &&
          (sumInventDim.InventColorId    == inventDim.InventColorId)
     exists join wmsLocation
    where (wmsLocation.InventLocationId == sumInventDim.InventLocationId) &&
          (wmsLocation.wMSLocationId    == sumInventDim.wMSLocationId) &&
          ((wmsLocation.locationType    == WMSLocationType::Buffer) ||
           (wmsLocation.locationType    == WMSLocationType::Pick))
        //do something
        //sumInventDim.InventLocationId,
        //sumInventDim.wMSLocationId,
        //sumInventDim.wMSPalletId,
        //sumInventDim.InventBatchId,
        //inventSum.AvailPhysical,
     if (appl.inventUpdateOnhandGlobal().inventUpdateOnhand().mustAddInventSumDeltaOnhand(itemId))
        ttsId = appl.inventUpdateOnhandGlobal().inventUpdateOnhand().ttsId();
        from inventSumDelta
        where (inventSumDelta.ItemId == itemId) &&
              (inventSumDelta.TTSId == ttsId) &&
              (inventSumDelta.IsAggregated == NoYes::No) &&
              (inventSumDelta.AvailPhysical != 0)
         join sumInventDim
        where (sumInventDim.InventDimId      == inventSumDelta.InventDimId) &&
            //do something
            //inventSumDelta.AvailPhysical,
dynamicsaxtraining: Production life cycle Blog bot DAX Blogs 0 16.07.2011 01:23
dynamicsaxtraining: Quarantine management Blog bot DAX Blogs 0 11.01.2011 21:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
dynamicsaxtraining: Item setup: Item group Blog bot DAX Blogs 0 12.11.2009 17:05
Часовой пояс GMT +3, время: 20:46.
