Старый 04.10.2011, 19:11   #1
25,644 / 848 (80) +++++++
paruvella: AIF – Update – The parameter index is not valid
Источник: http://paruvellas.wordpress.com/2011...-is-not-valid/
In recent days, working on AIF – Update action, and find one strange error as mentioned below. Error: The parameter index is not valid. Trying to solve the same, and then have checked on the parameter schema, it was defined as follows… So realized, we need to submit two XML’s for the update scenario, or [...]
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 19 Blog bot Dynamics CRM: Blogs 0 26.08.2011 01:13
emeadaxsupport: Problems when trying to update a certain field with AIF Blog bot DAX Blogs 0 19.08.2009 18:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
axStart: What to do when AIF is not working and how to code: Blog bot DAX Blogs 0 23.12.2007 17:51
Часовой пояс GMT +3, время: 03:19.
