Старый 22.08.2011, 23:11   #1
emeadaxsupport: How can I slipstream Cumulative Updates for AX 2012 as part of a new installation
Источник: http://blogs.msdn.com/b/emeadaxsuppo...tallation.aspx
We recently had a request to know if the recently released Cumulative Update 1 (CU-1) can be "slipstreamed" as part of new installation of Microsoft Dynamics AX 2012 (AX2012). So traditionally, in previous years if you wanted to build a new set of AX servers running the latest Hotfix Rollup Update (RU), you will for example install Microsoft Dynamics AX 2009 and after the install completes install the latest RU.Now with AX2012, you can automate the process of installing a cumulative update as part of the install.
To create a slipstream install extract the contents of the Cumulative Update (e.g. extract CU-1 self-extracting package DynamicsAX2012-KB2579565.EXE) into a subdirectory on the installation image under the “Updates” directory (i.e. .\Updates\KB2579565\).
Please note only Cumulative Updates for Microsoft Dynamics AX 2012 are supported for slipstream, other type of hotfixes will need to be installed manually as per the fix instructions..
--author:Carl Gibson, Anup Shah--editor:Anup Shah--date:22/Aug/2011
daxdilip: Step by Step Guide How to Install Dynamics AX 2012 - Part 1 Blog bot DAX Blogs 0 18.08.2011 18:11
furnemont: How-to series: Send SMS messages from CRM 2011 (part 3) Blog bot Dynamics CRM: Blogs 0 13.06.2011 12:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part IV Blog bot DAX Blogs 0 01.06.2011 04:14
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Часовой пояс GMT +3, время: 03:37.
