Старый 18.08.2011, 04:11   #1
emeadaxsupport: Searching for KB articles on Internet Search Engines
Источник: http://blogs.msdn.com/b/emeadaxsuppo...h-engines.aspx
You've probably used Knowledge Base (KB) to help troubleshoot an issue or answer a question. Check out this list of the KB articles that are most viewed for Microsoft Dynamics AX
2503850Description of hotfix rollup 7 for Microsoft Dynamics AX 2009 Service Pack 12405516Description of hotfix rollup 6 for Microsoft Dynamics AX 2009 Service Pack 1982812Hotfix rollup 5 (982812) is available for Microsoft Dynamics AX 2009 Service Pack 1959494Microsoft Dynamics AX 2009 components are install into an incorrect directory or you receive an error message when you install the Microsoft Dynamics AX 2009 reporting extensions on SQL Server 2008893082How to install a Microsoft Dynamics AX hotfix
By the way, you’ll find it’s easier than ever to locate KB articles for Microsoft Dynamics AX. You can continue to use PartnerSource and CustomerSource to find KB articles. In addition, you can now search, find, and view those same articles using a search engine like Bing.
Here are a few search tips for you. Use the words “Microsoft Dynamics AX" in your search to help narrow down articles to only the AX product and no others. Also, if you want to limit your search to Knowledge Base articles, use the abbreviate “kb” in your search.
For example, if I want to find information about how to import customers and vendors in Microsoft Dynamics AX, in Bing I’d search on the following phrase with the quotes:
"Microsoft Dynamics AX" kb import
When I do that, one of the first things that pops up is KB article 960729 titled “How to import customers and vendors in Microsoft Dynamics AX 2009”.
Try it and see what you think!
--author:Lynn Mueller--editor:Anup Shah--date:17/Aug/2011
Microsoft Dynamics CRM Team Blog: Creating an Elegant Codeless Universal Search Blog bot Dynamics CRM: Blogs 0 15.07.2011 19:11
emeadaxsupport: Opening AX client opens two external internet explorer windows Blog bot DAX Blogs 0 20.06.2011 16:11
Leon's CRM Musings: A Codeless Universal Search For Dynamics CRM Blog bot Dynamics CRM: Blogs 0 08.06.2011 15:11
Inside Dynamics AX 4.0: Common Search Blog bot DAX Blogs 0 29.10.2007 10:50
Часовой пояс GMT +3, время: 15:39.
