Старый 20.07.2011, 23:16   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Microsoft Dynamics AX Enterprise Portal: How to add hyperlink field to AxGridView
Источник: http://blogs.msdn.com/b/emeadaxsuppo...xgridview.aspx
To add hyperlink to your AxGridView you need to use AxHyperLinkBoundField (msdn: http://msdn.microsoft.com/en-us/libr...(v=AX.50).aspx)
The most important properties are following:
DataSet: Data set (AOT \ Data Sets) from which data are loaded
DataSetView: Table from which data are loaded
DataField: Field name from which data are loaded
MenuItem: Url menu item (AOT \ Web \ Web Menu Items \ Url ) where we have set up url
Example (from Web Form EPSalesTableInfo)
Code Snippet
--author: Czesława Langowska --editor: Czesława Langowska --date: 20/July/2011
emeadaxsupport: Running AX 2009 Client raises error: "An invalid directory structure for Microsoft Dynamics AX was detected" Blog bot DAX Blogs 0 01.04.2011 06:13
Microsoft Dynamics AX 2009 White Paper: Overview of Enterprise Portal Vadik DAX: База знаний и проекты 0 25.04.2009 15:27
epblog: Microsoft Dynamics AX Enterprise Portal Development and Deployment Webinars Blog bot DAX Blogs 0 23.04.2009 16:05
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
Часовой пояс GMT +3, время: 13:39.
