Старый 07.06.2011, 12:11   #1
axinthefield: XBRL Taxonomy (Import & Export of reports)
Источник: http://blogs.msdn.com/b/axinthefield...f-reports.aspx
XBRL : eXtensible Business Reporting Language (XBRL) (Global Financial Reporting initiative)
Reporting: Financial statements, information, non-financials information and regulatory filings.
Use the XBRL feature in Microsoft Dynamics AX 2009 to:
  • Import taxonomies
  • Convert taxonomies into row definitions
  • Map the Chart of Accounts
  • Generate the XBRL financial statement
Import File:
Path: General Ledger > Setup > Posting > XBRL Taxonomy
Export File:
Path: General Ledger > Reports > Transactions > Periodic > Select out put type = XBRL
This enables tab 'XBRL'
XBRL specific versions available are 2.0 & 2.1. (Select the version required, latest version is 2.1 and find the following URL to understand XBRL specifications)
URL: http://xbrl.org/SpecRecommendations
Specify the file name & location to store
This creates an xml type file for the data.
Microsoft Dynamics CRM Team Blog: Fetch-Xml based Reports: Bits & Pieces Blog bot Dynamics CRM: Blogs 0 24.02.2011 21:11
ukcrm: Gartner & Forrester Analyst Reports Blog bot Dynamics CRM: Blogs 0 04.07.2009 15:05
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 19.10.2008 18:05
Dynamics AX FAQ: How to import and export data in XML format using Axd classes? Blog bot DAX Blogs 0 18.06.2008 20:05
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 25.03.2008 03:58
Часовой пояс GMT +3, время: 05:26.
